Question about Oki Electric Industry Okidata - B6300N SMART FORMS SOL DIGTL MONO PR 35PPM 120V - 91632404
Okidata Please reboot printer 116-321 - Oki Electric Industry Okidata - B6300N SMART FORMS SOL DIGTL MONO PR 35PPM 120V - 91632404
How can i clear printi queue
on the computer- go printers and devices , printer - printer queue or printer tasks
high light tasks not required and delete
Oct 23, 2016 | Office Equipment & Supplies
What does this error mean: Please reboot. printer (116-324);
power cycle the printer. switch off and on
see further here for similar printer error my okidata com
Jun 08, 2016 | OKI B6200 Laser Printer
Install ibm proprinter ii in windows 7
Hola Gabriel, puedes dar mas datos. Could you give us more info please.
Ya intentaste con los drivers originales de Okidata?
Did you already try with its original drivers? http://my.okidata.com/dsdownWeb.nsf/driverlookup/D7BFA5764F4784E98525767E00689DED?OpenDocument
Sep 17, 2012 | Matrix Okidata Microline 320 Printer
I can't figure out how to feed paper into the printer
hello
i assume you refer to ML591, dot matrix ?
go to this link, and download users guied and/or manual http://my.okidata.com/PP-ML591.nsf?opendatabase
how feed the paper http://my.okidata.com/PP-ML591.nsf?opendatabase
Jan 11, 2011 | Okidata 591 Printer
How to Connect an Okidata Microline 321 to a new computer
If you have the software I would install it and see if it works if it does not Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} you may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Required printer driver
Driver is free from Okidata....just choose which operating system you are using and download here:
http://my.okidata.com/pp-ML320Turbo.nsf/openingdrivermenu?OpenFrameSet
Dec 28, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
MY PRINTERS KEEPS PRINTING OVER TOP OF ITS SELF
Hi amyellis, please click on this link below which will take you to okidata ML320Turbo's page. http://my.okidata.com/PP-ML320Turbo.nsf?
Download the pdf manual for you're ML320Turbo.
For English click here: http://my.okidata.com/mandown.nsf/1fe7d58578ca7f99852569af0042834b/e08d475cb4b6bf4a852569590039ffc6/$FILE/ae320tug_07.pdf
Once opened click the + sign next to Index. Than click the + sign next to Paper. Than click the + sign next to Paper jams. Follow the instructions to clean out paper build up within the printer. This is the most likely reason the paper is not moving.
Within the pdf file in the upper left hand corner is a small icon that looks like a gray floppy diskette. Click it & save the manual to you'r PC drive. You may need it from time to time.
Good Luck!
Have more questions? Please feel free to ask.
Mike
May 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Model# GE5253P
An online manual here: http://my.okidata.com/PP-ML320.nsf?opendatabase There is probably a top of form setting which needs to be checked & corrected. I assume you've checked tab/margin settings in your software & printer setup?
Sep 28, 2007 | Matrix Okidata Microline 320 Printer
Oki Electric Industry Okidata - B6300N SMART FORMS SOL DIGTL MONO PR 35PPM 120V - 91632404 Logo
48 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Randolph Tidwell
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
