Question about Tunturi T60 Folding Treadmill
Showing unfold treadmill
Lights on, key in but message unfold machine keeps showing
Spirit 776 treadmill will not unfold
I think you may need to put it in fold mode first...it may be in incline mode.
Dec 28, 2013 | NordicTrack Treadmill
Bad relay message and circuit breaker is pushed in and stuck
reset the machine and follow the step and fix it.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 21, 2013 | PaceMaster Exercise & Fitness
Hello, I have a Paradigm T801 showing the error message ERR 40 Over Acceleration. Is there any easy fix for that problem?
Reset the machine and proceed wit this steps. God bles you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Oct 02, 2013 | Paradigm Exercise & Fitness
Ironman Quest Treadmill Unfolds Improperly
see the video and proceed according. God bless you
Jun 08, 2013 | Proform Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
My Proform 785 will not unfold even after I have pulled the latch. Is there something else I need to do to unfold it?
You may have damaged the treadmill when folding it up. If the incline was not lowered to its minimum position, the frame can be damaged.
To lower the treadmill, all you do is release the latch and lower the deck of the treadmill to the floor.
There are many Proform machines known as "785" including a number of elliptical trainers. An actual model number would make diagnosis much easier...
Feb 26, 2011 | Proform 785 Treadmill
How i unfold it?
There is allot of weight on the "Storage Latch". You may need to push forward on the treadmill a bit, pull the black knob, then slowly let the machine unfold. Taking the weight off the "Storage Latch" will make it easier to release the latch..
Dec 16, 2010 | Nordic Track NordicTrack A2750 PRO...
Describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
May 31, 2010 | Proform Exercise & Fitness
3 yr old Smooth Fitness 7.1HR Pro won't Unfold
Did you unlock the lift control? You have to rotate the knob that is just above the pwer switch to let the unit lift or lower.
Feb 23, 2010 | Smoothfitness Smooth Fitness 7.6 HR Power...
Unfolding the deck on treadmill
From the owners manual:
HOW TO LOWER THE TREADMILL FOR USE
1. Hold the upper end of the treadmill with your right hand.
Pull the latch knob to the left and hold it. It may be necessary
to push the frame forward as you pull the knob to
the left. Pivot the frame downward and release the latch
knob.
2. Hold the metal frame firmly with both hands and lower
it to the floor. CAUTION: Do not grip only the plastic
foot rails or drop the frame to the floor. Bend your legs
and keep your back straight.
Jan 08, 2009 | Proform XP Weight Loss 620 Treadmill
Tunturi T60 Folding Treadmill Logo
19 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
