Okidata Please reboot printer 116-321 - Office Equipment & Supplies
What does this error mean: Please reboot. printer (116-324);
power cycle the printer. switch off and on
see further here for similar printer error my okidata com
Jun 08, 2016 | OKI B6200 Laser Printer
Install ibm proprinter ii in windows 7
Hola Gabriel, puedes dar mas datos. Could you give us more info please.
Ya intentaste con los drivers originales de Okidata?
Did you already try with its original drivers? http://my.okidata.com/dsdownWeb.nsf/driverlookup/D7BFA5764F4784E98525767E00689DED?OpenDocument
Sep 17, 2012 | Matrix Okidata Microline 320 Printer
I can't figure out how to feed paper into the printer
hello
i assume you refer to ML591, dot matrix ?
go to this link, and download users guied and/or manual http://my.okidata.com/PP-ML591.nsf?opendatabase
how feed the paper http://my.okidata.com/PP-ML591.nsf?opendatabase
Jan 11, 2011 | Okidata 591 Printer
Printer error fuser temp
This is a common error especially if you have power surges or outages, before calling in follow the following steps:
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  5. switch the first digit from a 0 to a 1
  6. press OK
  7. Press the Red Stop button
Now you need to clear the error
  1. press the down arrow
  2. Press #
  3. press the letter T ( on the keyboard of the printer)
It should reboot itself although it may not, if it doesn't then turn off the switch then back on. you should see some black bars flashing on teh screen. This clears the error and wil help determine if the fuser is actually broken. Before you print and start using it you have to set it back to operational mode by doing the following steps
  1. Press the Down Arrow
  2. Press *
  3. Press #
  4. select "SOS1"
  5. Change first digit from 1 back to 0
  6. press OK
  7. Press the red stop button
Those are the steps required to clear the fuser temp error from the okidata support desk
* Please rate this solution and provide comment
Nov 12, 2010 | Okidata B2500 MFP Printer Laser
How to Connect an Okidata Microline 321 to a new computer
If you have the software I would install it and see if it works if it does not Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} you may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Required printer driver
Driver is free from Okidata....just choose which operating system you are using and download here:
http://my.okidata.com/pp-ML320Turbo.nsf/openingdrivermenu?OpenFrameSet
Dec 28, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
MY PRINTERS KEEPS PRINTING OVER TOP OF ITS SELF
Hi amyellis, please click on this link below which will take you to okidata ML320Turbo's page. http://my.okidata.com/PP-ML320Turbo.nsf?
Download the pdf manual for you're ML320Turbo.
For English click here: http://my.okidata.com/mandown.nsf/1fe7d58578ca7f99852569af0042834b/e08d475cb4b6bf4a852569590039ffc6/$FILE/ae320tug_07.pdf
Once opened click the + sign next to Index. Than click the + sign next to Paper. Than click the + sign next to Paper jams. Follow the instructions to clean out paper build up within the printer. This is the most likely reason the paper is not moving.
Within the pdf file in the upper left hand corner is a small icon that looks like a gray floppy diskette. Click it & save the manual to you'r PC drive. You may need it from time to time.
Good Luck!
Have more questions? Please feel free to ask.
Mike
May 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Model# GE5253P
An online manual here: http://my.okidata.com/PP-ML320.nsf?opendatabase There is probably a top of form setting which needs to be checked & corrected. I assume you've checked tab/margin settings in your software & printer setup?
Sep 28, 2007 | Matrix Okidata Microline 320 Printer
k24674
