Question about Delphi Roady XT XM Radio Receiver
Roady XT Transmitter problem
This morning I found that the station I was using on my FM receiver was taken over by a Canadian Station and it knocked out my XM signal. I tried to select another FM station and when I select menu the FM Transmitter selection no longer appears. Anyone know how I can get it back so I can reset to another open station?
  • bechan Jan 06, 2008
    I have the same problem. I just bought the Roady XT and the "FM Frequency" option showed up once and now I can get that selection off Menu any more. I've tried 6 times in my car to no avail. Please help.
  • jmk730 Jan 30, 2009
    brand new roady xt. menu button does not produce FM Frequency as a menu option though the user manual clearly describes the method for choosing an fm station as going to menu and choosing FM Frequency then choosing fm station by moving arrows up or down
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
Posted on Jan 11, 2008
    Problem Solver:
  • 14 Answers
Maybe I can help >>http://www.youtube.com/watch?v=EU4qKOvb4hM
Posted on Jul 03, 2007
    Problem Solver:
  • 9 Answers
The youtube solution seems to have been removed from Youtube so I will fill you in on what I know. I have purchased a couple Roady XT's in the past year for various reasons. One that I received never had the FM transmitter menu option. XM Canada insists that some Roady XT's came built that way because of broadcasting standards. Having an extra XT on hand, I asked them to deactivate the XT that didn't have the FM transmitting ability with the other one which did. The only way to listen to the one without a transmitting ability is by the line out which isn't always an option unless you have a tape deck or line in to your stereo or deck. I love the FM transmitting ability because of the awesome range. When buying these units, if this is an important feature, be sure to ask if it is included.
Posted on Jan 16, 2008
SOURCE:
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
My roady xt does not have a fm select option on the menu
You need to have it in the AUTO base/cradle - AND - you cannot have anything plugged into the LINE OUT or AUX OUT jack, as it will disable the FM transmitter. Try unplugging the audio output, then you'll be able to select the FM transmitter again. I believe that they removed the option from the HOME cradle/dock all together because of regular AM/FM radio stations complaining to the FCC that the transmitters were too strong (in other words, they wanted to hurt satellite radio competition or slow it down as much as possible by forcing Sirius and XM go back and redesign their radios for a much weaker or NO FM transmitter).
Nov 07, 2010 | Delphi Roady XT XM Radio Receiver
Roady XT XM Radio Receiver: how do I change the radio station i want my xm to ...
First of all find a clear fm stn. on your car radio.Go to xm radio and push menu until fm freq. shows up.Push sel and use up or down arrows until the freq. matches that on car radio. push select again to set it.
May 07, 2010 | Delphi Roady XT XM Radio Receiver
Trying to figure out what FM frequencies are avail for my portable XM in my car? 50595 is my zipcode.
KQWC 95.7 is the only FM station that is out of webster city which is the 50595 zip code.
Jan 27, 2010 | Delphi Roady XT XM Radio Receiver
Connection
If it has a radio get a fm transmitter you just plug it into the roady headphone jack, You can find them about every where they make them for iPods but they work work these way too. there about 20 to 25 dollars on the net
Feb 02, 2009 | Delphi Roady XT XM Radio Receiver
Antenna message on roady display
I have the same problem. I hooked it up to a different antenna and it works
Nov 04, 2008 | Delphi Roady XT XM Radio Receiver
Stations dropped
Go to refresh.xmradio.com and insert your radio ID and click submit, it will send a refreshed activation signal to your radio and you should have your channels back within about 15-20 minutes
Jul 15, 2008 | Delphi Roady XT XM Radio Receiver
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
Connecting via a cable to my car radio
The best way to hook up this radio to your car is wireless! This radio has a built-in FM transmitter. All you have to do is go into the menu on the radio and find FM settings. Figure out or set the radio station, and then tune into it on your car.
Aug 17, 2007 | Delphi Roady XT XM Radio Receiver
XM Roady2 Built in FM Modulator not working
It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
Feb 01, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi Roady XT XM Radio Receiver Logo
961 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Larry Tezekjian
Larry Tezekjian
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
