Question about Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25
Idylis humidifier leaks - Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25
Humidifier is producing water but it is leaking and not going into bucket. Suggestions?
The only thing I can suggest is getting a new one. In theory, it should be possible to just fix whatever the problem is. In theory. However, should the problem repeat itself, it might come to the point where the total cost of ownership will outweigh the cost of getting a new humidifier. I would suggest something like the Honeywell HCM350W. It's a little bit bulky and you'd need to change the filters regularly, but it's a good and not very expensive humidifier.
Jan 30, 2017 | Humidifiers
How can I get an owners manual for this humidifier?
'This humidifier'? The one you have in front you that we can't see and don't know what it is?
Google is your friend in such cases. Google
Make model manual.
Feb 09, 2016 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Mine is leaking badly. It is not overfilled. any ideas why?
It most likely it the valve on the supply tank not properly stopping the flow of water into the basin resulting in it overflowing. Mine is doing the same thing and I am trying to find replacement parts.
Jan 22, 2015 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Idylis S55C-AE1 humidifier leaks water on floor
My idylis humidifer is lealng where you put the water canister, after about 15 minutes from starting unit
Feb 26, 2014 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Idylis #0484756 unit shuts off tank emply but take is full
Just purchased a Idylis model 0484756 and it has no
operators manuel. Is there one available?
Where?
Thanks
Jan 20, 2014 | Humidifiers
What are the setting recommendations for idylis humidifier #1 HUM 10 140 whole house system?
I plugged my Idylis whole house humidifier Model #1 HUM 10 140 in and all it shows is two lines. Will not work? What is wrong?
Nov 27, 2013 | Humidifiers
Will not power on
Throw it in the trash and buy you a better one !
Nov 10, 2013 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25 Logo
340 people viewed this question
Top Idylis Humidifiers Experts
Mack Baxter
Dennis
Are you an Idylis Humidifier Expert? Answer questions, earn points and help others
