Question about Dishwashers
I have a frigidare dishwasher and it washes the dishes, but it does not draim all the way.What could be the problem?
    Scholar:
  • 93 Answers
Check the hight of the drian pipe if it is too high the pump will not pump all the water out (about half the hight of the machne is usually good)also switch the machine off and blow on the back end of the drain pipe then check if any foren objects are in the machine wich may have caused an obstuction in the pipe hope this helps
Posted on Jan 21, 2009
What is the time on wash cycle GE, Frigidare, and Maytag dishwashers?
it differs quite alot depending on the model and brand, typical normal wash times can be anywhere from 45mins to 3 hours
Oct 01, 2014 | Whirlpool Dishwashers
Frigidare ultra quiet 1 top wash arm not cleaning properly
Hello ezideas - First I suggest verifying that there is enough water pressure coming into the unit and that it is at least 120F. Do you noticed if the spray arm will rotate freely or if it is damaged? If so, the spray arm assembly may need to be replaced. Connect with a professional to accurately pinpoint any potentially more serious issue.
Jan 14, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidare dishwasher model # NDB 631 RF 53. Washer runs but does not dissolve soap and jet tablet. Does that product not work with this dish washer?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 24, 2010 | Dishwashers
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher will not drain
You have separate draim pump under the machine.
It is either clogged or bad.
Remove it, check it for debris.
Clean it.
If no debris, replace it.
Mar 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not cleaning the dishes
Hi there. Here are some solutions that may help you combat this issue with the non cleaning of the dishes during the wash.
• Choose another cycle for longer washing
time.
• Check rack loading section for proper
loading—avoid nesting items.
• Home water pressure may be too low—
should be 20 to 120 pounds per square inch
(psi).
• Check incoming water temperature. It
should be at least 120°F (49°C). (See
Factors Affecting Performance.)
• Check water hardness. For extremely hard
water, it may be necessary to install a water
softener. (See Detergent Chart.)
• Use fresh detergent.
• Check to make sure funnel in top rack is not
blocked.
• Make sure items are not blocking the spray
arms, preventing them from rotating.
• Check to see if the rinse aid dispenser
needs refilling.
Next, you mentioned in your text that you were experiencing a burning scent after the was or during it. i have a few solutions for that as well.
• Soiled dishes left in dishwasher too long can
create an odor. Use Rinse & Hold cycle.
• There will be a "new" smell when first
installed. This is normal.
• Check to see if unit is draining properly.
One more thing, sometimes food or plastic dishware will fall between the spaces in the basket that holds the dishes. these plastics can be burned by the heating element inducing a burning scent during the drying process. always make sure that all plastics are secure before you start the cycle. food can get stuck on this heater element as well causing a burned smell.
Feb 15, 2009 | Dishwashers
have you cleaned the fliter in the bottom
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
Frigidare Dishwasher/rolls around
Nick, check the spray arms themselves to make sure they are not clogged, cracked or split. You have a seperate wash and drain motor on this model. It could be the filter under the lower spray arm is completely clogged with food gunk. You would have to remove the spray arm and get down to the filter. The wash motor itself has a small impeller on the end. It may be broken or the motor itself is bad. You would have to pull the dishwasher, the wash motor comes off very easily with just a couple of screws and you can examine the impeller. Catriver...post back
Oct 03, 2006 | Frigidaire 25 in. FDP750RC Free-standing...
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
