Question about Kenmore Elite 45986 Front Load Washer
Just got a new washer now my drain is overflowing
I understand that I need a bigger drain pipe to remedy this problem but, I have a bigger problem. My home was built on a slab. the 1 1/4 inch pipe comes out of the cement floor. How do I remedy this problem without getting a jackhammer?
  • 640 Answers
Ok thats easy enough,,i dont do plumbing but i know appliances,,,go to one of your do it yourself home improvement places and purchase a plastic sink,,,sink has to hold 16 gallons ..or more,,add it to your pipe in the floor and let the water drain into tub first...the most your unit will drain at any one time is 14 gallons,,wash or rinse,,..onthejob...also you can place this truff anywhere with some pvc,,,hold thing might run 49.99..tops
Posted on Jan 23, 2009
Washer empties faster than pipes allow causing overflow
More then likely you have a partial clogged drain also, New washer output is alot faster, Being a plumber its not getting enough air to let it drain properly. Check drain for clog and vent is wrking properly
Mar 01, 2010 | Washing Machines
Ge FRONT LOADER WASHING MACHINE DRAINS TOO FAST AND IT OVERFLOWS OUT OF THE DRAIN PIPE ONTO THE FLOOR. IT HAS 1 5/8" DIAMETER DRAIN PIPE. SOLUTIONS???
Yes, the new front loaders do drain much faster...I find that you need to have a 2" drain for them to work properly without over flowing the standpipe.
Now, what can you do??
You can add on to the standpipe and get it up higher, this will do two things... the higher lift will slow down the pump a bit, but will make it work harder and possibly fail quicker...the higher stadpipe will give you a bit more reserve space for the water to collect and then flow down and catchup after the intial burst of flow from the pump. The higher pipe will also create a bit more pressure to push the water down the pipe.
The next and better fix would be to install a bigger standpipe and trap. Go right back the the main line and run a new 2" line and trap to the washer.
I assume that you checked the existing pipe and trap for blockage....but thought I better throw that out there...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | GE WSXH208A Front Load Washer
My washer drain pipe is overflowing on my floor
Sounds like your drain pipe is restricted or clogged. Try using a "Pipe Snake" to unclog.
Jul 26, 2009 | Kenmore 500 6953 Dryer
Washer drain problem
You have no problem with the washer, your problem is the pipes have a build up in the that is restricting the outflow of the water. This happened to me and I replaced the pipes.
Jul 02, 2009 | GE WJSR4160DWW Top Load Washer
Drain pipe for washer overflows..how do I clear it out?
if the water is coming up from the drain it means your drain is restricted you either need a plumber or you have to run a plumbers snake down the drain to clean it outl.
May 30, 2009 | LG WM0001HTMA Front Load Washer
Drain pipe overflows from washer
Something is blocking the drain and it can't keep up with the flow now. You can try cleaning the drain with an auger (available for not much money at home supply stores). You'll probably find a sock or lots of lint built up.
May 13, 2009 | Kenmore Washing Machines
Overflowing drain pipe
it is ok to use a stand pipe that is 1 1/2 inch. the problem is that you need a new plumber!!! really you need someone that has a drain cleaning machine and can cut through all the years of lint and debris that has built up inside the pipe.
they will use the same type of head that is used to cut out tree roots from drains. make sure they know what they are doing before you agree to pay them, most good companies will charge about 50-75 bucks to clean the drain out.
also try the unit before the plumber leaves to make sure the drain is clean and doesnt back up.
Dec 09, 2008 | Whirlpool GSC9455 Top Load Washer
Water overflows from drain pipe
2 ins is rather small and there may also be a partial blockage somewhere in the system you are not aware off.
a naughty cure is to restrict the drain hose of the machine so water comes out a bit slower
Sep 05, 2008 | GE WBSR3140DW Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
117 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
