Hi.Ive had my machine for three years but it has only been out of the packaging for four months or so. Every time I try to use it now, it starts the selected program then after thirty seconds or so tries to empty and the timer clicks forward continuously. Could somebody please help as im starting to get whiffy. Thank you , Andrew.
1st switch off appliance, put timer knob to a stop position...switch it back on...some lights may flash quick, this is the timer/pcb re-setting memory chip.. then try selecting a new prog... if still not working check filter it may be blocked..which will stop water from emptying thus timer click rounds.. also if you have moved into a new house..make sure that the drain pipe under sink hasn't been blocked of..
ps each time you try something...re-sett timer, as it will store last point...so you need to resett...
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
The door has stuck with washing but no water. the handle is loose but the door is stuck firm.......
(More)
The door has stuck with washing but no water. the handle is loose but the door is stuck firm.... took the top off but i cant find a way to release the door solenoid... can you help??
HI, The door handle on our washer dryer has broken (gone very loose) and will not open. Ive taken...
(More)
HI, The door handle on our washer dryer has broken (gone very loose) and will not open. Ive taken the top off the machine to see if i can open it from the inside and i cannot seem to find any lever or switch to open it. All i can see is a long oblong plastic casing that i can only assume is the soleniod as its got wires coming out of it. Any ideas how i operate the release mechanism? Alan
just received new handle in post but having difficulty fitting it, not sure how it all goes back...
(More)
just received new handle in post but having difficulty fitting it, not sure how it all goes back together. need to know which way the spring goes.
