Question about LG Washing Machines
Wdp4wh pedestal installation instructions - LG Washing Machines
Need assembly instructions for kokols pedestal combo sink in clear
Is this any help?
https://sites.google.com/site/bathroomfurniturevanitysink/installation-on-vanities/glass-vanity-set-up-guide-kk09
Otherwise you could send them an email:
http://www.kokolsinc.com/pages/contact-us/
Apr 20, 2015 | Kokols Clear Vessel Sink Pedestal Bathroom...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Crankshaft Position Sensor and Camshaft Position Sensor
REMOVE OR DISCONNECT
  1. Serpentine belt from the crankshaft pulley.
  2. Raise the vehicle on a hoist.
  3. Right front tire and wheel assembly.
  4. Right inner fender access cover.
  5. Using a 28 mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Crankshaft harmonic balancer using tool J 38192 or equivalent.
  7. Sensor electrical connector.
  8. Foreign object deflector.
  9. Sensor and pedestal from block face.
  10. Sensor from pedestal.
INSTALL OR CONNECT:
  1. Loosely install the crankshaft sensor on the pedestal.
  2. Position the sensor with pedestal attached on special Tool J 37089.
  3. Position the special tool on the crankshaft.
  4. Bolts to hold the pedestal to the block face, torque to 20-40 Nm (14-28 lb.ft).
  5. Torque the pedestal pinch bolt to 3-4 Nm (38-40 lb.in).
  6. Remove special tool J 37089.
  7. Place the special tool 37089 on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
  8. Balancer on the crankshaft.
    • Apply thread sealer (GM 1052080) or equivalent to the threads of the balancer bolt.
  1. Torque the crankshaft bolt to 140 Nm + 56°(104 lb.ft + 56°).
  2. Foreign object deflector.
  3. Electrical connector.
  4. Inner fender shield.
  5. Tire and wheel assembly, torque to 140 Nm (104 lb.ft).
  6. Lower the vehicle.
  7. Serpentine belt.
Jun 02, 2009 | 1994 Buick Regal Gran Sport
I have front loading washer/dryer;need to install pedestals.
Yes!!!! Do not lay the machines on their backs with out the shipping bolts/hardware installed..Major damage will occur!!!!!
clarkco
Feb 28, 2009 | GE WBVH6240F Front Load Washer
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
Dec 31, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool WHP1000SQ 10" Pedestal this came with no instruction where can i get on line instruction
if you want to put the pedstal on unit..lay unit on back.pull draw out of pedestal ,than lay pedestal on back then put the bolts or screws in though pedestal ,,and stand ...
Dec 24, 2008 | Whirlpool WHP1000SQ 10" Pedestal In White
Panasonic Viera TH-37PX70 Pedestal Stand
i need the instrucation how to install the pedestal stand
Sep 18, 2008 | Televison & Video
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
