Transmission problem of a washer Whirlpool model LXR7244JQO
Good morning, it,s about a Whirlpool topload washer model LXR7244JQO. D'not want to spin. It wash and rinse but when it come to spin the bowl d'not spin. Only the water run out.
Good morning.
The problem lays in the transmission. From outside when you turn the universal (connector) the bowl with the brakes don't turn with the main shaft. When you open the transmission, remove the clip of the big plastic gear. After you lift up the plastic gear you will notice that one or two of the plastic parts are worn down. By replacing you will solve the problem.
Posted on Jan 22, 2009
Won't spin in final spin cycle.
transmission shot if it does everything else but spin,not worth fixing for the price of a transmission plus labor,just junk it and buy a kenmore,whirlpool top load-mike
Apr 28, 2009 | Washing Machines
Wont spin
the motor coupling is bad to get to it you can lean you machine back and you will see the pump take the 2 clips off it then there is 2 on the motor you will have to take the screws out of these once you get the clips off the motor the motor will come down and the motor coupling is on your motor shaft and transmission shaft
Dec 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a toploading whirlpool washer LLR9245BQ0. When it reaches the spin cylce it makes a clanging sound, like it would be off balance but its not.
Hi thanks for the question. the problem your having ,is with the motor drive coupling . located between the motor and the transmission . replace the drive coupling .thanks the appliance doc
Oct 06, 2008 | Whirlpool Washing Machines
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Frigidaire washer topload, Agitates but the tub spins
yes the problem parts of the transmission if your going to keep it have new transmission installed
Jan 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Lsb6300pw whirlpool topload
does it wash have you tried on wash since youve had the spin promblem
Jan 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
217 people viewed this question
Top Washing Machines Experts
