SERVICE MODE I NEED SERVICE MODE FOR HISENSE TC2961L I WANT TO CORRECT VERTICAL AND RGB tv is SLITHLY RED
Try
With user’s RC 1. Power TV On 2. Press Menu button and call up User OSD Menu 3. Select Sound-> Balance 4. When Balance value is “0”,Enter 0->5->3 ->2 in sequence. Note: If necessary, re-do number keys. 5. Factory OSD appears. 6. Press the standby button then AC turn off and restart the TV, which can exit factory OSD menu.
Posted on Mar 07, 2010
  • jzoramthanga Jun 06, 2013
    This is not the answer
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
How do I unlock the setup options for horizontal & vertical adjustments on my 55" HDT 51M 2006 Plasma TV won't let me access the horizontal or vertical options in setup in RGB 1 mode.
You have to enter the service mode option to it, to do horizontal and vertical adjustments. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 25, 2014 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Can't change the aspect ration from wide to normal on my hisense tv ltdn46v86us
You might have to enter its service mode options to adjust this fault. Actually entering in to service mode, and making data adjustments with it, is really a skilled work. Anyway, visit this site named'Electro-help'. Entering into service mode proceedings to many brand TVs are described in detail. Check it and determine whether you can do it by yourself or not. If you are not sure, do not get in to this mode, and make any adjustments there. Check this link, and select the site named above. Pull up older posts there.
Jul 26, 2012 | Hisense Televison & Video
There is a red tint displayed throughout the picture
Main baord or even power supply are possible with main being most likely.
Jun 02, 2012 | Samsung LN40A630 40 in. LCD TV
JVC HD-52Z575 red screen
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
Feb 20, 2010 | JVC HD-52Z575 52" Rear Projection...
Red and blue convergence wont line up. What should i do.
convergance can be tricky and you should follow a manufacturers proceedure from a manual.
most specificaly start with the green H and V Linearity and center , then the Red and Blue
Projection TV's and Component Video RGB have their Horizontal and Vertical Sync signals on the Green Component..
There may be other reasons for their specific order of operations within a calabration proceedure such as your 'RGB convergance alignment'
Jun 16, 2009 | Hitachi 43FDX01B TV
Hisense Television Model TC2961L
Double check all of the buttons on the remote as well as the t.v. and be sure that none of them are stuck.
Aug 05, 2017 | Televison & Video
Connecting component video YPbPr to TV with BNC port for RGBHV
No, this will not work. Picture will roll vertically. Originally they intended for HDTV to be red,green, blue, & Horizontal, Vertical sync. That changed after the first generation mitsubishi's.
In the service menu you can change the settings for the HDTV Input. Try that first by "Hitting menu button followed by 1259" or menu 1257. Let me know how that works for you, If you need a different code for service menu...contact me again and i will look it up for you. But the answer to your question is you can make it work or you can purchase a 300.00 box that will allow you to switch to that input thru..mitsubishi.tv.com
Good luck and keep me posted. GURU JAY
Dec 08, 2007 | Mitsubishi VS-50605 50" Rear Projection...
HISENSE TA42P-HDRA
I am from Tunisia & ibought a tv plasma HISENSE from CHINA 2 years ago;i have a vertical white line(10cm) in the midle of my plasma(Hisense 42"),after 10 mn the tv is on.What can i do?
Oct 31, 2007 | Hisense TA42P-HDRA Television
Televison & Video Logo
1,187 people viewed this question
Top Televison & Video Experts
