Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
Fan on cozy wall heater(outside vent runs continuously
The tech guy said it was probably the thermostat--and I'd be better off buying a new unit rather thareplacing the thermo(if that iIS the problem) --is he right??and is it the thermostat, or what??P>S>
  • Cozy Master
  • 3,089 Answers
Whats is it doing ?
Posted on Jan 22, 2009
Cozy heater banging and clicking
Well if it's considered an unsafe situation, please, for your own safety, hire you own experienced expert for a second opinion. Get the results in writing, and if it shows an issue that can be resolved exists, present it to the home owner and ask for a refund off the rent. If that unit has a cracking, creaking to it, probably just the metal heat exchanger expanding and contracting. It's a new unit with new noises, and may take time to get used to. Now if its a louder bang or piping sound, there may be an intermittent issue that needs to be addressed.
Mar 24, 2017 | Cozy (W352E) Heater
I have had problems with my Cozy gas wall furnace since it was new (its about 6 yrs old now) I won't stay on. It seems that every year I have to call out service people to get it to work. It always...
if the switch at the top of unit is tripping there is something wrong with the vent , the switch is set at 350 degrees it detects back draft do to a improper vent or blockage of vent, if the installer use the old vent system that is more than likley the problem, have the installer call Cozy tech line at 502-589-5380 so they can go over how the unit is installed.
Dec 07, 2010 | Cozy (W352E) Heater
My older Cozy cf353c counterflow wall heater gas shuts off pilot after it has run a while. I replaced the bad fan switch thermostat[ fan would not run untill changed] but not the other lemit switch . Could...
first have the heat exchanger inspected for a hole or crack, if there is an oval to round adpt. on top of unit or an elbow in vent this can cause the heat exchanger to split open and also cause what you are talking about.
Jan 14, 2010 | Cozy (W352E) Heater
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
I have an outside vented wall mounted heater.It heats the room and before it shuts off the room gets as cold as when it started running.does that make sense?
What you might be hearing is the fan before it shuts down, the burners quit long before that. You might have a sticking fan switch thats letting the blower run to long and blowing cool air. You didnt say if your unit has a blower, I have to assume.
Feb 24, 2009 | Cozy Heating & Cooling
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
85 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
