Question about Microsoft Windows Vista Ultimate Edition
What is the difference between Java editor and Java software?
I want to know What is the difference between Java editor and Java software?
  • 68 Answers
Java editor is a text editor which probably understands java language synthax and can automatically call java to compile your code.
Java software is a program written in Java programming language which is interpreted/executed by JVM(JAva virtual machine) on a target computer.
Your question is a rough equivalent to : What is a difference between typewriter and a recipe book written in English language
Posted on Jan 21, 2009
    New Friend:
If we look to this question as a view of programmer Java Editor are the software where we can write our java code. There are IDE such as Eclipse, here you can write and compile your code and see the result in the console which is at the bottom of the screen
What is the difference between Java editor and Jav - difference-between-java-editor-java-he13p1vhmjhe0wjz1icxfo3b-1-0.png we can also write our java codes on text editor such as Notepad++
But to compile this code and run the program we need to use cmd or command prompt
difference-between-java-editor-java-he13p1vhmjhe0wjz1icxfo3b-1-5.png So basically java editors are places where you can write your java codes.
The answer of second part of your question is that java softwares are the softwares which are written in java programming language.
Posted on Oct 02, 2015
    Sergeant:
  • 281 Answers
By Java editor I am guessing you meant the IDE (Integrated Development Environment) for programming and compiling in Java? If so then you need JDK (Java Development Kit). As others have mentioned previously, you can write Java code using any text editor but to actually compile that code into a program you would need the JDK which also includes the JRE (Java Runtime Environment)
The JRE is runtime interpretor that will translate the java code from your program into machine language so that your computer will understand. Java programs and software require the JRE to be installed on the computer in order to run.
Posted on Jan 24, 2015
    New Friend:
    Problem Solver:
  • 11 Answers
Any text editor can be used as java editor to edit the java code. Java software is required in your system to run any application developed in java.
Posted on Jan 01, 2015
Tm u220 java
Are you printing from inside a java program (output) or from a java program editor.
Use the command to Open an output file, have all your output sent to the output file, close the output file properly before you exit the java program. After you finish send the output file to the matrix printer as you would with ASCII file. If the printer is installed properly, your OS should know where to send the output.
Dec 23, 2013 | Epson TM-U220 Matrix Printer
Crash
There is a ongoing problem with software using Java. Java requires constant updating due to security issues, the software that uses Java must keep pace, often they do not. POGO games is a good example, I've found the Java 1.6.0.29 version works, but when you open POGO it asked you to update Java, If you do it will not work, Go Figure? That said your MPS Rocket may be different and of course there tech support will tell you it's a Java Issue. Open Control Panel, select Java, open Java tab, view, what version are listed? Take a look at the other settings, exceptions, etc. The newest version of Java 1.7.0.21 32 or 64bit, that may be a issue, your OS is 32 or 64bit? You may have to add 32 bit Java to a 64 bit OS. It can be a bit of a handful.
May 07, 2013 | MP3 Rocket
Top 3 Best PDF files Editor?
you can use OpenOffice.org writer its free and best
Jun 05, 2012 | Computers & Internet
How to write a software
you need to know programing language to develop a software, different programing language that u can make software in are microsoft visual basic.java microsoft c sharp
Mar 20, 2011 | Computers & Internet
Winrar file doesnt download properly, so tried saving as .jar file, but dont know to instal .jar .jad files on Winddows xp pc
Both of these files .jar and .jad are JAVA files a programming language by SUN. The jar file contains many compressed files and can be run on a PC with "Java Runtime Environment" (JRE) can be downloaded from Java.com. The .jad file is also a JAVA file which is used with java virtual Machine (JVM) ME used for games and application development for cell phones. There are completely different from WinRAR which is used for folder compression and no you cannot install those files on the PC. Only .exe or .msi can be installed on the computer.
Download WinRAR compression software from the web if you already do not have it if you like to decompress a RAR file.
Nov 06, 2010 | Computers & Internet
I want java for programmng....so can u tell which java version to download and send the link for it?
If you want to do standard programming, download the Java SDK (also known as JDK). If you want a free editor in which you can write code, compile it, test it and so forth, download the version with NetBeans. The link is: http://java.sun.com/javase/downloads/index.jsp
Jun 08, 2010 | Sun Java System Web Server 6.1...
What the different between srinc & source
Sinc is a domain controlled by two servers. They are on different IP networks
Source
project oriented program code editor and code browser, with built-in analysis for C/C++, C#, and Java programs,
Nov 03, 2009 | Inverter Yaskawa F7 Drive
Sch s259 how to convert videos to .mjpg(motion jpeg) format my problem is video converter mjpg. please send software.
sch s259 how to convert videos to .mjpg(motion jpeg) format
Mar 01, 2009 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
332 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
