Question about Cambridge Audio Audio Players & Recorders
Failed power transformer
The power transformer has failed and i require a spare. who can supply this item
  • peter reynolds Jan 21, 2009
    Maker- Cambridge audio
    'A' series integrated amplifier
    Model A1 V3.0
    Tx no. NC-V4282TA1
    3200-428201-400
  • cscheffler Feb 06, 2009
    Exact same component failed. Opened up amplifier and used multimeter to verify that 240V AC goes into the transformer and nothing comes out. No information other than part number (NC-V4282TA1, 3200-428201-400) written on transformer.
  • 4,234 Answers
With out make and model, I can not supply parts information. Please update this with that info. Also, depending upon the age of the unit, parts may not be available. Are you sure that the problem is the transformer? This part is rare to fail.
Dan
Posted on Jan 21, 2009
Will not heat water, cavity light and touch panel are working ok
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Magnetron used with no load.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it. Using the microwave with nowhere for the energy to go results in magnetron meltdown!
The magnetron may be all that is required but the diode pack may also have failed. These components are Safety Critical Items and MUST be replaced with identical units for continued safety.
Spare parts are available through the Manufacturers Authorized Agent. Go online to find a supplier near you.
Hope that helps.
Jan 08, 2011 | Microwave Ovens
Microwave works but does not heat the food VM1440BH01 is the product #
Hope that helps.
Hope that helps.
Jan 08, 2011 | GE Microwave Ovens
My husband heated up water this morning....no problem. 2 hours later, I tried to heat up my mug of coffee and it came out cold....absolutely not heating. any help you can give would be great! model...
Hope that helps.
Hope that helps.
Jan 08, 2011 | Kenmore 63252 Microwave Oven
Microwave turns on but does not get hot. make a funny noise
Hope that helps.
Hope that helps.
Jan 08, 2011 | GE XL1800 1100 Watts Microwave Oven
Everything works but it doesn't cook...no heating whatsoever
Hope that helps.
Hope that helps.
Jan 08, 2011 | LG LMV1630ST Microwave Oven
Microwave operates but no heat is being generated
Hope that helps.
Hope that helps.
Jan 08, 2011 | GE JE1530GW Microwave Oven
A Marshall 100w amp that lacks heater voltage on all tubes
Yes, it is the power transformer that has failed. If you are comfortable with replacing it then do so just be careful. If you could though I would be careful and check to see what power you are getting at the transformer just to make sure
Feb 06, 2009 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
Sony 36" Trinitron
The power supply section is having trouble.
Common possibilities are:
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 22, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
382 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
