Question about MPC Computers Envision EN 7100s 17 in. Flat Panel LCD Monitor
My Envision EN 7100s
Wen i switch on the lcd i get withe screen ( brighte ) no signal ?????? thankesssssssss
  • ramadan elbakuri Feb 01, 2008
    i tray what your told me but noting happen ( resoldering the capacitors) .
    tankssssssssssssssssssssss
    bakuri
  • MPC Computers Master
  • 12,061 Answers
OK this unit more than likely has a Power Supply failure, Usually the Electrolytic Capacitors in and around the Power Stage. They Dry out and go faulty.. and cause this type of problem.
Posted on Jul 24, 2007
SOURCE:
I have an Envision EN 7100s monitor. It works just fine when I run the computer in safe mode, but when I try to start the computer normally the screen will go blank after the microsoft logo and say "Input...
Doesn't really sound like the monitor is the cause. The video driver sounds like it might be failing on load. You can try starting in safe mode, open device manager and remove the video card from the hardware list (You can also do this with add and remove hardware in the control panel of XP). Restart and let windows install fresh drivers on start up. This may help if the driver installation has been corrupted. Note that you will need the original driver disk if you want the extended options of your video card, otherwise windows will install the generic windows driver which in some cases is no different from the factory driver.
Hope this helps,
Gill
Oct 07, 2010 | MPC Computers Envision EN 7100s 17 in....
Is this a good monitor, will it work with windows7
From what i have just read by looking on google.
Its a very nice monitor, and it is fully compatable with any version of windows
Aug 01, 2010 | MPC Computers Envision EN 7100s 17 in....
Input not supported
The repair shop set the PC video resolution to higher resolution to use with their monitor and did not put it back to the same resolution for your monitor which cannot handle the higher resolution. You need to lower the PC video resolution to the native reslution of your monitor which is 1280 x 1024 @60 Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 14, 2010 | Envision EN-7100e 17" Flat Panel LCD...
GReen flashing light and the monitor will not come on???
Please verify that it does the same with other PC.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Envision monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 27, 2010 | MPC Computers Envision EN 7100s 17 in....
I can see a faint image on the monitor but the screen is realy dark. Looking closly I can see all the control functions but the screen brightness is gone. Is this a bad power supply #CH-1205 or the...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 08, 2010 | MPC Computers Envision EN 7100s 17 in....
I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Have a hewitt packard computer, want to add on envision monitor 7100s The system is not accepting monitor. what do I do?
To reinerate,do you have the driver for it? I am sure that  the old monitor was made by HP for your HP computer.
Go to the Envision website and download the LCD driver and install same.    Link provided below:
http://envisiondisplay.com/support.asp?EPage=support&SMenu=driver
Mar 23, 2009 | MPC Computers Envision EN 7100s 17 in....
MPC Computers Envision EN 7100s 17 in. Flat Panel LCD Monitor Logo
95 people viewed this question
Top MPC Computers Computers & Internet Experts
Thomas F. Schneider
Joaquim Martins
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
