Help with External USB HArd Disk
I just bought a New USB Hard disk 250GB. i know how to make partitions. is therer a way i can lock & hide a partition?
  • graphilinx Jan 22, 2009
    is there a free way?
  • graphilinx Jan 27, 2009
    does the software automatically update with the internet?
  • 416 Answers
yes, there are ways you can do both. if you want to lock a folder there are several programs online that you can use to do so. for example a software called folder lock. http://www.newsoftwares.net/folderlock/
this program will create a folder that can be locked.
if you want to hide the entire partition the try some thing like storagecrypt (this software can do both locking and hiding) http://www.magic2003.net/
hope i was helpful.
Posted on Jan 21, 2009
  • 3 more comments
  • chinthaka Jayasinghe
    chinthaka Jayasinghe Jan 21, 2009
    try googeling for folder lock
    chinthaka Jayasinghe Jan 22, 2009
    hello,
    yes, there are ways you can do both. if you want to lock a folder there are several programs online that you can use to do so. for example a software called folder lock.http://www.newsoftwares.net/folderlock/
    if you want to hide the entire partition the try some thing like storagecrypt (this software can do both locking and hiding)http://www.magic2003.net/
    hope i was helpful.
    chinthaka Jayasinghe Jan 23, 2009
    Appriciate you feed back
    if
    if
I have a Simpletech signature mini 250 gb external hard drive,it shows as unknown usb device and has no drivers.Do you know where I can download these missing drivers?
hi your hard disk got problem
but check in control panel > administrator tools> disk managment if there is any drive that not formated you lost your partition or got viruses otherwise your hard disk physically is damaged
Sep 01, 2011 | SimpleTech Signature Mini 250GB External...
Windows 7 does not recognized it
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click Administrative Tools.
4. Double-click Computer Management.
5. Select Disk Management under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hdd.
Good luck and thanks for using FixYa.
Dec 27, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
My toshiba 250gb external hard drive doesnt show in my computer (xp) but it is in device manager?
Click Start
Right-mouse click My Computer
Click Manage
Expand the Storage branch
Click Disk Management
Click Disk Management (local)
Click to create a partition on the drive, and to assign a drive-letter.
Oct 27, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Wd 250gb laptop HD only shows 118gb
In XP Start > Control Panel > Administrative tools > Computer manager then on the left click disk managment, you will see your 250gb drive as drive0 most likly with partition C and beside it you should see unallocated space, you can right click this unallocated space and format it, then right click again and click make partition active.
Jun 20, 2010 | Western Digital 250GB MyBook External USB...
Partition external hard-disk
You can partition your hard drive using any of the available free partition tools such as EASEUS Partition Master or Partition Logic. You can even buy tools like Partition magic to do the same job.
Please rate if Helpful.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Says 4gb not 250gb.
It sounds like your OS (windows XP+, I presume, as it's NTFS) is reading the wrong partition information from the hard disk.
Use this (free) partition software to delete all partitions on the external drive (and make VERY sure that it's pointing at the external, and not your main hard disk!).
http://www.partition-tool.com/personal.htm
...so delete all partitions; make a new one and see if that is 250 GB.
If yes, format.  Sorted.
If no, you could try editing the partition table directly with this:
ftp://ftp.symantec.com/public/english_us_canada/tools/pq/utilities/PTEDIT32.zip
...you'll again have to be careful you're working on the right hard disk.  To use this, you'll need to know the number of heads, cylinders etc.  This data might be on a label on the disk (inside the external drive case), or you might be able to get it from the disk's manufacturer; either on their website or by emailing their tech support.
If editing the partition table doesn't work, or if the numbers keep reverting/changing, then it's highly likely that the hard disk is stuffed.  Only thing to do then is replace the hard disk in the external case (make sure you swap for the same type: IDE for IDE and SATA for SATA); or explore your warranty options.
Hope that helped.  Good luck!
Mar 03, 2010 | Freecom (24358) 160 GB Network Hard Drive
I have a toshiba external drive 250GB. model HDDR250E03X. I believe the socket for the usb cable is loose...sometimes its working, most of the times now--its not! I already bought a new usb cable but still...
I have experience this error recently.
Normally these drive with high capacity like yours need to be installed with usb 2.0 cable and connected to a usb port that support usb2.0
Check if your motherboard support this.
Also if you are using an extension cable or a usb port hub try to bypass this and connect directly to the mainboard at the back
One thing more
At times new Hard disk need to be formatted, so go throught disk managemnent and locate your disk to create partition and format the Hard disk.
If you need more help
please revert back
I will be glad to help you for further problem.
One thing you can do is to check your Usb port with another device eg: a usb pen or usb printer.
ok
cheers
Uttam
Jan 26, 2010 | Computers & Internet
If i re creat partition my data in disk is lose ? which is placed in other drives...
If you have your data in other drives then you do not loose anything. Only this drive data will be lost as the whole disk is formatted after partitioning.
Sep 20, 2009 | Western Digital 250GB MyBook External USB...
USB External HArd Disk
Jan 22, 2009 | Televison & Video
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
