Question about Magicard Avalon Duo Thermal Card Printer
Ribbon install
I loaded the ribbon and it keeps giving me an error message
F380 printer will not SCAN - keeps giving error message
Do you have original CD with you? if not down load the full feature drivers from hp web site. Un install the drivers, re-install once again..verify your driver CD supports the OS what you are using?..
Feb 03, 2012 | HP DeskJet F380 All-In-One Printer
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Explanation: This is an advisory message. The message appears when
the welded part of the ribbon is moving across the Hammer Bank.
Corrective Action: None. Wait for the ribbon to finish moving, and the message will disappear.
Apr 21, 2010 | Tally T6218 Matrix Printer
Hello, my zebra ZM 400 keeps giving me the message of paper out/ribbon out I have replaced both rolls, powered down. Printer feeds one time, then keeps giving the same message
please kindly check the ribbon and label... make it sure that it fits exactly or properly or correctly fits the said consumables... if its not work check the settings...
Nov 17, 2009 | Zebra Z4Mplus Label Printer
I HAVE RIBBON OUT ERROR WHEN THERE IS CLEARLY A RIBBON IN PLACE. MESSAGE STILL APPEARS AFTER PLACING NEW RIBBON IN,
Enter the Menu system on the front panel, cycle around until you find calibration. Press the select button here and follow the instructions, when it asks for you remove ribbon remove it, it will ask to load the backing. Remove a label from the backing and let it do its thing, eventually it will ask you to load all. Re-install all the media and it will calibrate, after this it will fix your error. If it doesn't there will be a sensor that has failed.
Oct 21, 2009 | Zebra Z4M Printer
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Magicard Avalon Duo Thermal Card Printer Logo
23 people viewed this question
Top Magicard Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
