Question about Mitel 8528 Digital Phone 50006122
My mitel 8528 phone has a loud alert that I can't change
My ringtone is a loud alert that I am unable to change.
How to change ringtone in Lenovo Q330?
Feb 03, 2013 | Cell Phones
My LG shine does not alert me when I receive txt messages. how can I change that?
Hello
Your phone is probably on silent or you havent selected a tone for your text messages. Go to your tones,select a particular ringtone you want to use for your text mesages select "options" and select ''set as message alert tone" and select ok.
Jun 09, 2011 | LG Shine KE970 Cellular Phone
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
Okay well i have the lg Xenon and i keep my phone in my back pocket and for some reason after school i took it out and turrned the volume on and my ringtone change to this "mesage from (persons name)" and...
That happened to me ! I had to go into settings, then reset settings. you won't lose anythinng. and if you haven't already changed your security pin or whatever it is 0000
Aug 18, 2010 | LG Xenon GR500 Cell Phone
Changing ringtones and alerts on sony satio
I believe that you go into settings/personal/profiles. There you can highlight an existing profile or create a new profile. When you highlight a profile you can select option button, then tap personalise and this with give you options to change ringtones, ring type, message alerts etc. Hope this helps
Nov 02, 2009 | Sony Ericsson Satio Cell Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Change ringsyles - which button to press to change the message tone and ring tone
use the <>v^ to select and press ok(menu button) to set. go to settings, media, audio listen to the ringtone you wish to have..click options pick what you want that ringer for (alert, messages or caller)...click ok
have fun.........
Jun 19, 2009 | Motorola Mobility RAZR V3
Change ringtone on phone
go to your main menu, click options, then click profiles(ring tones), then click which profile you would like to change (ex. loud, vibrate), once it has "(active)" next to it, click on it. then you can click on phone, SMS text and so on. then you just pick the ringtone
Jun 09, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I don't have any ringtones on my phone or I am looking in the wrong place.
1. Go to 'setup'. SELECT IT.
2. It has the first option as 'Ringer Alert Style'. SELECT THAT.
3. You will find type of alert styles like: Ring Loud / Ring Soft / Vibe and Rig Loud etc.
4. Select the ringer type you use (You will not get any ringtones on silent or vibrate mode).
5. Select Edit. You will now find options of ringtones.
Hope this solves your problem.
Mar 10, 2009 | Motorola Mobility ROKR E6 Smartphone
Incoming messages alert tones
first of all open menu of your phone then tap on setup(the one with screw driver on it) icon to open it then select ring alert style and select your alert style you will see a bottun bellow displaying "EDIT" tap on it then a menu will apear with volume level, Ringtone line 1, Ringtone line 2, Massage tone....
you can edit all of them by taping on the folder type icon flashing in front of them......!!!!!
I think it will help you...if not then reply me at ik1788@gmail.com
Feb 02, 2009 | Motorola Mobility MING A1200
Mitel 8528 Digital Phone 50006122 Logo
1,076 people viewed this question
Top Mitel Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Mitel Health and Beauty Expert? Answer questions, earn points and help others
