Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My windows xp keep rebooting after shutdown
Hi I have windows XP since January and I recently have a weird problem, my computer reboot after I click shutdown. I have the automatic restart option off. Does someone have a solution for this weird problem?
  • Anonymous May 16, 2008
    wont tunn off
  • 944 Answers
You should be able to change this setting in the PC bios menu. Windows XP should interact with this and change it automatically, but it occasionally doesn't. If you have trouble finding the appropriate menu and changing it, please post back with details of your PC (ideally motherboard make and model) and we can hopefully talk you through it. When the computer starts up, there should be a screen before the windows XP screen which says something like "press f8 to enter BIOS setup", but all machines are a little different. If you can get into the BIOS setup, only change things which you are sure you know what they will do, or you can cause all sorts of problems. Hope this helps, post back with system details if you need more :)
Posted on Jul 02, 2007
It might be the problem in your smps also or just clear your CMOS or enter f8 button while booting and stop restarting in the option"stop restarting windows "
Posted on Nov 06, 2008
SOURCE:
How do I restart or reboot my whole system and start fresh.I have a Dell latitude D430
Dell not given facility to reboot. But command through you can reboot . To access the command prompt window from Vista or Windows 7:
  1. Go to the Start menu
  2. Type cmd in the Search field
  3. Press Enter
On a Windows XP computer:
  1. Click the Start menu
  2. Choose Run
  3. Type cmd
  4. Press Enter
From an open command prompt window, you can type shutdown, and then the option you wish to execute.
To shut down your computer type: shutdown /s
To restart your computer type: shutdown /r
To log off your computer type: shutdown /l
0r
press down window key with and two time press "U" key.
Sep 19, 2013 | Computers & Internet
HOW TO REBOOT
Click on the windows symbol, normall on the bottom left, then click on SHUT DOWN or RESTART symbol on that menu that just popped up. It is normally on the bottom right of that menu.
Mar 31, 2013 | ASUS Computers & Internet
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
How can i reboot my acer laptop
Press Start(ORB at bottom left for vista/w7) and if you're on windows 7/vista, there should be a list button on the bottom right side of the start menu saying "Shutdown"(windows 7) and "Sleep"(Vista), click the list and click Reboot.
On XP you need to click the Shutdown button and before you click shutdown instead click Reboot(Green button If i recall correctly).
Jul 15, 2011 | Computers & Internet
How do u reboot your computer
rebooting your pc is as simple a pointing your mouse to the lower left corner at the windows logo, then, left click it and left click restart..you are now rebooting your pc.
Nov 02, 2010 | Computers & Internet
What means of reboot ?
Reboot means to restart the Computer. All the opened applications will be closed and Computer will be re power cycled.
Jul 10, 2010 | Microsoft Windows XP Professional for PC
REBOOT MY PC WITH WINDOWS XP SP2
Using your left mouse button click on START in the bottom left-hand corner of the screen then click shutdown, then select reboot.
Alternatively hold down the crtl and alt key and with them held press the delete key, then select shutdown/reboot.
May 06, 2010 | Toshiba Satellite A15-S127 Notebook
Need to reboot my crashed computer cant get windows xp to reboot
HI how are u, ur Windows Xp is corrupted
Cause :
1. Viruses
2. Computer was not Shutdown properly
3. Some windows File Corrupted
Solution>>>>>>>1.
1. Go to Safe Mode at starting mode press F8.
2. If Computer Go to safe mode successfully>>
3. Go to start >> Programs>> Accessories>>System tools>>System restore.
4. Restore ur computer in privious date.
Solution>>>>>>>2.
1. Insert WIn xp cd in cd rom and restart it.
2. Repair Your win Xp via a Repairing utility.
Solution>>>>>>3
1. VIa a formmating utility U can install a new fresh copy of windowxs.
Thanxs
Mukesh Kumar
[email protected]
May 12, 2009 | Microsoft Windows XP Professional
How reboot my satallite pro laptop
To reboot a windows computer with Windows XP, click the Start button in the lower left corner, then click Shutdown, then Shutdown again in the popup box.
For a Windows Vista machine, click the windows Orb in the lower left corner, then the small arrow next to the lock on the bottom right of the start menu then click shutdown.
If you need to manually power off, hold the power button down for 5-10 seconds until the computer itself shuts off. This is only for when traditional methods do not work.
Jan 12, 2009 | Computers & Internet
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
294 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
