Question about Goodmans GTVL32W27HDF 32 in. LCD TV
I have a goodmans lcd tv model gtvl32w26hdf wont turn on
I have a Goodmans 19"
TRY AND RETUNE .THIS IS DONE IN THE LCD MENU
Sep 12, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Hi there i have a goodmans gtvl19w19hd 19inch tv and just wonted to know if it has freeview on it any where as i can not seem to access it if it has it ....
Hello. I've just acquired one of these TVs. There is no freeview on this model. However there are Scart and HD connections so it's easy to plug in a freeview or FTA Satellite receiver.
Jul 11, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Hi, i require the instructions and remote for the 19" Goodmans LCD TV model GTVL19W19HD can you help at all>
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 08, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Sound but no picture on my goodmans 32inch lcd tv was working ok then screen turned off
The LCD backlight is faulty. it may be due to bad capacitors or a faulty inverter controller. Bad capacitors can be easily replaced. A faulty inverter controller is a bit more tricky but it can also be replaced.
Mar 01, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans tv widescreen how do you take subtitles off
how do u turn subtitles off on my goodmans 32in tv, pls give step instructions
Dec 21, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
GOODMANS GTVL26W26HDF - no Remote control/child lock is locked!!
hi just got a goodmans x pro witout the remote any chance you could let me no how to turn it on as its just on stand by now thanks
Feb 06, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans model gtvl32w26hdf. Switched itself off. have changed fuse, with not difference. blue standby light comes on, using remote press standby blue light goes off, screen remains black.
Good Day SIr, sound to me like your switching power supply is not working properly, there is an IC that controls the switching action of your power supply, this MAY be the reason why it stays off. locate the IC at the power supply section, replace it then test. There is also a possibility of open low value resistors near the switching transistor (very hard to locate). hope this helps.
Sep 23, 2009 | Televison & Video
Goodmans GTVL32W27HDF 32 in. LCD TV Logo
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
