error 203 means , no change detected by the level switch when draining . possible cause
1, booster pump faulty
2, booster pump plug connector loose
3, start capacitor faulty
4, plug connector loose
5, boiler level switch faulty
6, no boost pump signal to- i/o pcb
7, no "boiler full" signal from i/o pcb check booster pump/ s2with manuel control
the most lightly or most common is the level switch in boiler tank will need changing
Your description for error 203 is misleading ? Please suggest rather that the folks call the factory...
(More)
Your description for error 203 is misleading ? Please suggest rather that the folks call the factory ? 800-868-3840 and get the latest and best professional technical assistance for Meiko Products. John
Dish washer does not reach proper temperature on wash cycle. Unit begins to heat water to approx. 98...
(More)
Dish washer does not reach proper temperature on wash cycle. Unit begins to heat water to approx. 98 degrees and then an error code appears on the wash cycle.
