Question about Kenwood KDC-252U
Kenwood 252u no audio - Kenwood KDC-252U
How to install a kdc 252u in impala 2005
Posted on Feb 10, 2014
    Problem Solver:
  • 10 Answers
Have you tried hooking up a test speaker that is not installed in the vehicle to see if the outputs work correctly?
Posted on Jan 23, 2013
I have a Kenwood KDC-252U stereo and it is stuck in the protect mode. I followed the instructions the best I can. Any help would be wonderful.
any relations with jack frost? protection comes on if you run it too loud but if its on all the time that would mean your internal speaker output is faulty. you have to tip it
Oct 18, 2014 | Kenwood KDC-252U CD Receiver with...
I have a 252 u and it will not reset it just says protect
Disconnect unit from power supply for at least twenty mins , it's most likely you have a short or crossed wire on the power side rather than a speaker wire problem you should have 2 x power one switched ( comes on when you turn the ign key ) and one permanent 12 volt , connect your radio earth to the car chassis to make sure you haven't picked up an aux wire from the loom.
Jun 22, 2014 | Kenwood KDC-252U
Kenwood kdc-252u keeps flashing protect
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
May 16, 2014 | Car Audio & Video
How can I program the kenwood kdc252u to turn on and off with the ignition? As of now the unit stays on after I turn the vehicle off, or stays off after I turn it on.
you have wires crossed or not hook up ignition switch for radio stereo power wire connects to cars ignition.stereo memory (yellow or orange wire) connects to constant power for radios memory(rad stations /clock)
Feb 26, 2014 | Kenwood KDC-252U
My Kenwood kdc-252u will shut off if I have the volume past 22. Also the sound becomes distorted at higher volumes. What's wrong and how do I fix it?
CHECK THE WIRING TO YOUR SPEAKERS FOR + AND - POLARITY. COULD ALSO BE A BROKEN SOLDER JOINT ON THE RADIO PCB AROUND THE OUTPUT AMPLIFIER CIRCUIT CHIPS/TRANSISTORS...LOOK FOR TWI PARTS ON A METAL HEAT SINK MOUNT. ALSO CHECK THE BATTERY OR 12V WIRE FOR A GOOD STRONG CONNECTION.
Oct 13, 2012 | Car Audio & Video
My oem car stereo will not keep memory, time or any presets once car is turned off?
Kenwood is not OEM make sure the memory wire gets power all the time.
Sep 25, 2012 | 1996 Honda Civic
I dont know how to program radio stations on my kenwood kdc-252u
If you are using auto search, the station you want on 98.3 may not be strong enough in that location. I had the same problem. If I drove to where the signal was strong enough, I could program it. That worked fine until the next time I had to program stations and the routine had to be repeated. Try driving around to find a "hot" signal location.
Sep 15, 2012 | Kenwood KDC-252U
Kenwood KDC-252U Logo
112 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
