Question about Home
There seem to be so many different types of ice cube trays: silicone, plastic, metal etc. What is the best type to buy?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
It sometimes is just a matter of taste. The silicone ice cube molds are more flexible and often take up less freezer space but some people don't enjoy the struggle of getting them out of the molds.
Read this article that reviews ice cube trays and gives an opionion on the best ones. For me - I still love the old fashioned plastic trays that don't flop around when you are trying to put them in the freezer;
http://gizmodo.com/5913538/the-best-ice-cube-tray-of-all-time
Posted on Jan 10, 2013
My family are big ice cube fans and I wanted to buy some molds that were a bit different from the regular shapes. Any ideas?
Actually you could go crazy. There are so many different ice cube trays out there, themes, shapes - you name it, they have an ice cube mold for it. Just check out amazon's range for some ideas.
Or take a look at this link, it's an article about unusual ice cube trays, personally I just love the snowflake ones;
http://www.toxel.com/tech/2009/03/24/20-unusual-and-creative-ice-cube-trays/
Jan 10, 2013 | Home
My Electrolux side-by-side refigerator automatically started dispensing ice cubes in the middle of the night and would not stop until I manually pulled the lever to the stop position. It did this on 2
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Aug 29, 2012 | Electrolux E23CS78HSS Side by Side...
I can only get crushed Ice when the Cube Button is pushed. it seem the Cube Buton has failed. What can I do to solve this problem
Pretty easy fix if you are somewhat handy with a screw driver. Remove the tray holding ice, on the side of that tray should be a metal rod that activates the crushed/cubed function. There is a motor on that activates a lever that will push the end of the rod down or pull it up depending on what you have selected.
Motor could have been frozen, since it is in the freezer, but you need to remove the mounting bracket and spiral rod assembly. To remove this there are two small bolts on the bottom of that bracket, remove those and lift up on the entire bracket assembly. This will remove from the mounting bracket at rear of freezer. Now for the hard part, you need to unplug the wire connection that runs into the back of the freezer. There are two plastic clips on each side of that connector. You need to push the top of those clips on both sides and pull the connector apart. All at the same time. The wire also is connected to the ice maker itself, so you also need to disconnect that connector, much easier to disconnect that, squeeze the clips on each side and pull apart.
Now you should be able to remove the entire ice tray and spiral gear assembly. Be careful as the light bulb is on the bottom back side and it is probably pretty hot as it has been on now for several minutes while you were trying to get all of this done. Now you need to take the back plastic cover off, by removing the two silver screws from the bottom rail. By removing the plastic cover you can gain access to the spiral gear motor and most importantly the cubed/crushed actuator motor. If it is anything like mine, it will be covered in ice crystals, let that melt or use a hair dryer to speed it up.
Once that is unfrozen, you should be able to move the metal rod (shaft) back and forth. There is a spring on the opposite end of the shaft from the motor and that will push or pull up the lever that in turn moves the rod to allow for cubes instead of crushed ice.
Once you have that shaft moving freely, reassemble the unit by replacing the rear cover with the two metal screws and place the assembly back in the freezer. Plug the harness back into the connector, it only fits on the female end one way, but you can look at the orientation of the round holes and square holes and get it lined up correctly. It goes together much easier than it came apart. The light bulb will turn back on once you have it connected correctly, don't forget to also connect pigtail connector to the ice maker itself. Now if you hold the door open/closed switch in and push the ice dispenser lever on front of door, you should see the motor push down the actuator that in turn will push down the end of the brass rod which then opens the latch at the dispenser end to allow cubed ice with out going through the crusher.
Make sure you have the cubed button on front activated before you test this. You will not see any difference by just pushing the cubed or crushed buttons on the front of freezer. You will only see a difference in that actuator once the ice dispenser lever is pushed. As long as that is working, make sure to replace the two metal bolts on the bottom of the mounting bracket. Replace the ice tray and enjoy your cubed ice. Hope this helps
Sep 09, 2010 | Frigidaire FSC23F7D Side by Side...
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Apr 02, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice cube are not dipensed only crushed ice
I had the same problem you do - the solenoid that lifts that white plastic piece is dead. But I also rent the place where I live, and it comes with the fridge. It's not likely the landlord will want to deal with this issue since I can still get ice, not considered a necessity, etc. So here's what I did to make it so that I always get cubed ice.
I have model# FRS26R4AW5. The ice dispenser wil
Jan 09, 2010 | Electrolux Refrigerators
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidare stuck on crushed ice.
I have a few ideas for you to try. On the bottom of the ice cube holder there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. The position of this plastic piece is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced.
Jul 06, 2009 | Frigidaire FRS26R4A Side by Side...
ICE WITH PLASTICS TRAY
the cubes that come out of most plastic trays are alot larger than the cubes harvested by the icemaker. these cubes can jam and cause the bucket to break. if you can find plastic trays that have smaller cubes it would probably work ok..peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Home Logo
137 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
