Question about THQ Alex Rider: StormBreaker for DS
What if i use Firmware Update of AK2i for console 3DS4.3 and DSi1.4.4. and my ds cannot read i just off but not complete
System Date error Please check NDS system date
  • The temporary fix is to set your date back a year (or six months) and things will be back temporarily back to normal.
  • To set back the date follow these steps.
  1. Completely remove R4 card.
  2. Touch the screen.
  3. Now you'll see a screen that says Pictochat in one box and DS Download Play in the other.
  4. Press the DS icon located below the two boxes.
  5. Now you will see four more boxes. Click on the blue box that has a calendar in it.
  6. Now click on the calendar icon and set the date back.
  • The reason this is happening (and it has happened to a TON of people) is software incompatibility.
  • The permanent fix is to update your software.
  • This is the link to NDS-Gear R4 card update. http://www.nds-gear.com/software-firmware-kernel-download
  • If your R4 card is from somewhere other than NDS-Gear then just go to their site to update the software.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 14, 2011 | Nintendo DS Console
DSi will not read R4i card, but regular DS will
The DSi comes with a protection for this kind of devices. You have to update the R4i firmware to make it compatible with the DSi.
Mar 22, 2011 | Nintendo DSi Red Console
When r4i card is inserted , dsi reads . An error has occured .Press and hold the power button to turn the system off.Please see manual
If your DSi has the most recent firmware, v. 1.4, then you'll have to wait to update your R4i when they release an appropriate update. http://www.r4dscards.com/R4i-DS-Card/
Feb 28, 2011 | Video Game Consoles & Games
Error code 51330 when setting up wi or ds
This is a router issue.
Try first updating your router's firmware (this alone may fix the problem.. remember to reboot your router after the update)
Second reset the router to factory defaults and set it up again for your internet.
after those are completed, you should no longer see this code.
Cheers!
Feb 23, 2011 | Nintendo Wii Console
Hello, Recently I have got a new Home-Hub and now I cannot seem to connect my DS to it. I've read into it and i think it is because my ne home-hub uses WPA and this version of DS only supports WEP. What...
In this case you can do one of three things:
1. Change your router's security to WEP (very bad idea as this is easy to hack through)
2. Buy a newer Dsi which will support WPA (up to wpa2 I believe)
3. You can try updating the firmware for your DS and see if that adds support for newer protocols
(you could TEMPORARILY set your router security to WEP just to update the firmware then immediately change it back once done)
** If you found this information helpful please leave feedback to help us to help others **
Feb 19, 2011 | Nintendo DS Console
When I turn my ds on it comes up saying loading... system data error!Please check NDS system date. how do i trouble shoot this.
There is a bug in the firmware of your R4 card.
Wil not work after 14 april.
You have to update the firmware of your R4 card.
Till you do that you can change the date back before 14 april so you can play directly.
Apr 16, 2010 | Nintendo DS Lite Console
AR won't read any games anymore!
Have you tried updating the AR firmware to the most recent update. That should work. If not try reinstalling it with your disk that the AR came with
Oct 05, 2009 | Nintendo DS Lite Console
Can not press next with Action Replay DS v. 1.60
this may or may not work, but you can try re-callibrating your touch screen (orange botton in settings menu with crosshairs) or download new firmware/update action replay from your computer..... YOU HAVE BEEN WARNED: IF YOU DOWNLOAD FIRMWARE OR UPDATE YOUR UPDATE ACTION REPLAY, CODES YOU HAVE ENTERED YOURSELF MAY BE DELETED, BE CAREFUL AND MAKE SURE YOU WANT TO RISK IT. (i found out the hard way)
Apr 15, 2009 | Nintendo DS Lite Console
Won't turn on after i tried to update for GOW2
You accidently bricked your PSP when you terminated the firmware update. When a Firmware update begins it formats the memory location prior to beginning the flash. If you interupt the flash or anything after the flash program erases the firmware memory location, the PSP will not be able to boot.
Send your PSP to Playstationclinic.com and they will restore it for a good price.
Dec 29, 2008 | Sony PlayStation Portable (PSP) Console
THQ Alex Rider: StormBreaker for DS Logo
100 people viewed this question
Top THQ Video Game Consoles & Games Experts
James Wishart
Sandeep Kumar
Edward Talavera
Edward Talavera
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
