Question about Compaq Computers & Internet
Pioneer dvdrw dvd k17 device burns the movie but it wont show . and wont work on my dvd player
  • Compaq Master
  • 2,386 Answers
You need to make a video dvd, by choosing video dvd option on burner
Posted on Jan 10, 2013
4 Suggested Answers
Sunil Panem
  • 80 Answers
SOURCE: pioneer dvd-rw dvr-k17 problem
Hi
Right click on the driver and then click Properties.
On the properties screen, check the device status and then go to the Details tab at the top.
If the details screen shows any errors or problems abt anything other than drivers, then follow the steps below to delete the upper and lower filters from registry.
Step 1: Back up the registry
  1. Click Start and and in the Start Search box type in REGEDIT and hit Enter .
  2. From the Registry Editor window, perform one of the following depending on the operating system:
Click File and then click Export File.
  1. The Export Registry File window will be displayed. Save In: should be set to the Desktop . Next to File Name: provide an easily identifiable filename like “Full Registry Backup”. In the Export Range portion of the window, make sure the radio button next to All is selected. Click Save to save an exported copy of the registry to the desktop.
  2. Step 2: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
  1. With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
    or
    • HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
  2. Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
  3. Click the plus sign [+] in front of Control.
  4. Click the plus sign [+] in front of Control.
  5. Click the plus sign [+] in front of Class.
  6. Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  7. With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
  8. Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
  9. Exit the Registry Editor
  10. Restart the computer. The optical drives should then be recognized and available for use.
Posted on Feb 25, 2008
SOURCE: HP Pavilion problems with the Pioneer DVDRW DVR-K17
try cleaning the laser lens if you can access it but i guess it is ery hard for laptops. Or maybe you an use an regular CD/DVD lens cleaner try that first. If it doesn't work and stil does the same, then you have to get the drive replaced because such drive rarely being repaird. it has got weak if not defective lens, or maybe motors but as i said this drives rarely being repaired and they always just replace the whole drive. you can eject the DVD/CD drive and get it checked with other Latpops it you have a friend who has one just for testing. thanks red
Posted on Apr 07, 2008
tcobiz
  • 35 Answers
I had the same problem, it occurred right after windows installed sp2 and my laptop showed no dvd player with any program, I restored my laptop to the previous day before the update and it worked fine again, after that I just let windows update by itself and it has been a week and everything is fine, also in device manager open the dvd + sign and right click your dvd and click update drivers, if that does not work, right click your dvd, and then click delete, and then reboot your computer, laptop whatever and the computer will automatically recognize the player on startup and it will install again and hopefully that will get your drivers updated, do not worry about deleting the dvd player, it will reinstall all by itself, just have to reboot..thanks
Posted on Jun 02, 2009
Pioneer dvdrw dvd k17 device what cds can i use for it
you can use any writeable cd/dvd in this drive.
Jan 10, 2013 | Compaq Computers & Internet
Pioneer DVR-K17 won't burn at 8X ! !
Maybe the DVD not support this speed!
Feb 05, 2018 | Pioneer DVR-107D DVD±RW Burner
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-K17B
I have the same problem. Has anyone found a solution? I have an HP Notebook dv6700 with a Pioneer DVDRW [DVR-K17B ATA Device]. For the past few months I haven't been able to burn anything to disc. I can't find any firmware updates online. I'm not sure if I need to buy a new drive?
Thank you in advance for any feedback.
Oct 26, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer dvd-rw dvr-k17 problem
it's windows problem.
basically you need to edit (delete) registry.
follow this step from microsoft.
http://support.microsoft.com/kb/314060
Aug 05, 2008 | Computers & Internet
Pioneer dvd-rw dvr-k17 ata device
no issue shut down the laptop reset the dvd i mean reconnect it and restart it will automaticaly pick up and if not then thee is a prob wd win they might be corrupted
May 20, 2008 | Computers & Internet
This sounds like you have a Virus or Some other type or Malware that has corrupted your drivers. Please Scan with Avast (http://www.avast.com/), Spybot S&D(http://www.safer-networking.org/), and Adaware (http://lavasoft.com/) all of witch have free versions.
Also it may be that your driver got corupted some othere way if it still does not work try roleing back your driver or updateing it.
Thank you,
Rel
P.s. if that does not work please come back and make sure you give the info that you have
scanned with the above and if you do not reply in this question then make sure you include all
that info with all the info you have already put here. Good Luck!
This worked: thanks to riozebratubo
delete the entires in regedit.exe
"UpperFilters"
"LowerFilters"
They're inside:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
-uninstall the driver
- restart
Vista is searching for existing drivers -> done
Feb 05, 2008 | Pioneer DVR-107D DVD±RW Burner
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
