Question about Crafts & Hobbies
When did die cutting originate? - Crafts & Hobbies
    Problem Solver:
  • 13 Answers
It started off in the mid 19th century as a way to cut leather for shoes.
Posted on Jan 10, 2013
What exactly is die cutting?
Die cutting is manufacturing a lot of the same shape from a material. You can do it with fabric or wood, plastic, etc. The shapes you create are called blanks and are usually used decorated before they are sold.
Feb 27, 2013 | Crafts & Hobbies
98 explorer starts then dies
Been in accident and repaired? Check all sensors are plugged in and all earth wires have been reconnected. Does it splutter and die or just cut straight out? If just cut straight out it will be a sensor/computer fault.
Nov 20, 2011 | 1998 Ford Explorer
My wife's 2003 Ford Escape lost all electrical
Too early I think to have the automatic collision shutdown system. These can be troublesome Had a car that wouldn't start after the lady slammed the boot shut.
Are you using the original ignition key supplied by Ford and not a cut copy ?
Aug 29, 2017 | 2003 Ford Escape
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
Cricut not cutting anymore
I was reading lots of forums and tech support pages on how to get my Cricut back online. I went to the store and got the Deep Cutting Blade & Housing and I got two replacement blades for the original housing that came with the Cricut. I also bought a pack of new mats. I replaced the original blade with a new one, used a new mat, and tweaked the depth and speed of my cuts and my little Cricut is whirling again!
Jun 25, 2009 | Provo Craft Cricut Disney Font Cartridge
HOMELITE 245 CHAINSAW. IT WILL START UP , BUT WHEN YOU START TO CUT WOOD IT DIES OUT. I HAVE CHANGED THE PLUG , CLEANED THE MUFFLER , AND CLEANED THE AIR FILTER. MEL
check gas tank vent and cap. Adjust carb a small amount ie. back out screw marked L 1/4 turn. If that does not work adjust screw marked "H" 1/4 turn out if no results adjust back to original position and go 1/4 turn farther in.
May 01, 2009 | Garden
Crafts & Hobbies Logo
162 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
