Bosch wfo2866gb wont work
The washing machine blew the MCB on the fuse board, the fuse in the plug is ok. There is no display when plugged in and the drum was still full of water when it stopped.
  • Washing Mach... Master
  • 17,129 Answers
Possible that the control panel had failed, there is a fuse within the control panel which needs to be checked. Most probably if this fuse has blown there is a short within the board which need to be confirmed for a board failure.
check this link to remove the panel: control panel
Posted on Jan 10, 2013
5 Suggested Answers
  • 2187 Answers
SOURCE: my washing machine fills but the drum is not
Check the wires for damages such as burns or loose connections. If that does not solve the issue check the door switch normally found 2 o'clock on the door frame. See if the lever is loose or may need replacement. If these checked out ok. Have the motor tested. See if it would run minus the load and the circuit.
Posted on Nov 11, 2009
venexcsd
  • 1185 Answers
SOURCE: Hotpoint , no power, full of water
Turn off the water supply to the machine
Take the drain hose off the back of the machine and drop it into a bucket , you will need to do this several times.(Take off any clips that stop it from being laid flat on the floor)
Once all of the water is out of the machine try powering it up again, if it lights up do a spin to get the clothes dry , leaving the outlet hose in the bucket.
If that works then once the machine is dry try turning on the water supply with the machine turned off , if water runs into the machine then you have a faulty fill valve.
If that is ok then check the pressure switch and Air Bell which sits on the back of the main drum you could have a soap ball in the Air Bell which will false out the machine and cause overfilling
If there is no power check the mains supply to the wall outlet then the plug top wiring and any fuse fitted inside the plug top
After that it is down to a man with a test meter
Posted on Jul 17, 2009
57 varieties
  • 1653 Answers
SOURCE: Bosch 1400 Exxpress washing machine : Turning off after a few sec
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Posted on Dec 05, 2009
Bosch washing machine logi xx7 no power cant open door. fuse ok
Check power at outlet and make sure you are getting power to the machine. If you are then the board on the machine may have had a surge and burned out
Sep 25, 2016 | Bosch Washing Machines
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Why is Display not turning on
take out the plug
check fuse
check the wires to the board from the plug not broken
the board may be blown?
Aug 17, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Bosch 2467/GB/06 no display no go
Check power on wall with some other gadget, check plug fuse....
Apr 27, 2013 | Bosch Classixx WFO 2466 Front Load Washer
My bosch washing machine Maxx classic wont turn on
Please check the main power from the power outlet the mains plug to the controller unit. If there is power then check within for the fuse, if fuse is intact then check for burnt items, if so the board could be damaged and needs a replacement. In most cases if the fuse has blown it is possible that the board has failed and so changing the damaged component could be difficult as the board is immersed in epoxy.
Sep 12, 2012 | Bosch Washing Machines
Washing machine starts but trips mains MCB, kitchen is on it's own ring main. Replaced fuse and reset MCB but tripped again, I'm thinking electronic fault, board maybe?
Sounds like short or Electrical leakage,,locate and disconnect the heating element then try this goes faulty now and then....Machine should then run /spin fill ...if so fit new heater
Feb 10, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
May 11, 2009 | Washing Machines
Power
just done a simple wash no problems, put on another wash on and a key appears where the timer appears and bleeps like it has finished a wash. could anyone tell me what this key means so I can carry on washing
Oct 13, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Jun 01, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
