Question about Canon PIXMA MP160 All-In-One InkJet Printer
Sensor problem I have a canon MP160 and despite my using only new cartaiges the sensor of the printer has failed and it shows no cartaraige or low ink in the recent past when i wanted to get it repaired i was told that the sensor has conked off, would request the good offices of cannon service people to have the same set right for me.Iam in mumbai and if you say where it can bes set right then i would take it or if the service people can come over and repair the same kindly inform.
Sir,
I am from Mumbai India can you suggest any specific canon centre in mumbai where i can get the same fixed up.
Thanks
Sunder Venkatraman
Posted on Jan 25, 2009
Canon MP160 Printer "Ink Absorber is Full
Canon MP160 PIXMA shows ink cartridge full. How do I empty...as I just refilled with new cartridge, due to stating no ink. Please help..thank you.
Mar 12, 2013 | Canon PIXMA MP160 All-In-One InkJet...
I've changed the ink cartridges in my MP120 twice and the display is still showing that the ink level is low. How do I get the printer to reset to show the correct ink level?
After the refill it indicate your ink level is low.... Don worry about that its nature... it doesn't happen any thing... All the canon printer indicate like that... thanks
Aug 26, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Black ink low but not
Are you using a genuine Canon ink cartridge? Sometimes remanufactured/refilled ink cartridges will fail to read correctly in inkjet printers.
Feb 28, 2011 | Canon PIXMA MP160 All-In-One InkJet...
In Canon MP160 i dont want to use its printer so is it possible to use only its scanner even it has dry or dammy cartaige?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq15
Jun 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon mp160 printer E5 flashing error?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
Feb 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
- unplug cable
- plug cable
Run the software.
oke
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
62 people viewed this question
old marine
old marine
