Sherwood PM9805 not turning
When turned on the motor pulley spins but the drive belt does not, as a result the turntable platter doesn't spin
My turntable does not work on a audio component system
Is the motor on the turntable spinning - wiring misconnected?
If motor is running then th epower is not being transmitted to the platter by either a belt drive or a pulley drive.. The belt or pulley has to be replaced to restore the missing friction
Mar 14, 2015 | Audio Players & Recorders
The turn table on my record player wont spin I can hear that it's on put wont spin.please somebody help
Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of courseicon1.png, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
Oct 29, 2013 | Crosley CR249TA Turntable
Platter not spinning
Is this a belt driven model? If so then just replace the belt. Also check that platter can turn. Sometimes grease or dirt builds up. If you can't turn it by hand then neither can the motor.
Feb 16, 2013 | Audio Players & Recorders
My Thorens TD150 MK2 Phono Turntable Motor will not run or spin with the belt on but will turn without the belt on.What is wrong.
If you can turn the platter easily by hand, then so should the motor. You can also disconect the power leads to the motor and hook up a PP9 9 volt battery to it. If it\'s slow and easily stopped from rotating then there\'s nothing wrong with the power to the motor and the motor is bad!
Dec 31, 2012 | Audio Players & Recorders
The turn table is going round but its playing the record to fast the speed seems wrong
Hello!
are you sure, that your speed selector is on 33.3rpm, not 45?
assume, it's in correct speed settings. do you know, that across the ocean power grid AC frequency is 50hz, in US it's 60hz. Means: ac motor will spin faster, than it should. If you bought this unit abroad, that's where is your problem at. some expensive units have 50/60hz pulleys switch, some not. Especially, if it's DC or direct drive motor. Check your owner's manual for specifications. May be you find an answer. If not, there is a problem with motor's regulator, which is built in(DC motor). Turntable is a belt driven. If you won't find 50/60hz adjustments, take it to repair shop.
Good luck,
Alex.
Jan 11, 2012 | Aiwa PX-E860 Turntable
Power is on, turntable won't turn
Hi, sounds like the belt was not refitted when the motor was replaced.
To replace drive belt on a Crosley turntable.
1. Remove the cir-clip holding the platter in place from the base of the centre spindle.
2. Lift the platter off. You may need to use a flat blade or some similar tool to get under the platter in order to lift it up.
3. NA.
4. Place the belt around the platter pulley making sure it is sitting flat without any twists.
5. Flip platter over the right way up
6. You will see 3 rubber grommets in the platter surface. Remove 1. Through the hole insert a belt hook, crochet hook, kebab skewer, knitting needle type tool and slip it
between the platter pulley and belt in readiness to fit over the motor pulley.
Nov 15, 2011 | Crosley CR249TA Turntable
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
The turntable won't spin
Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of course, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
Apr 10, 2010 | Crosley CR248 Turntable
Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
Feb 15, 2010 | Sony PS-LX250H Turntable
My turn tabel isnt spinning
The drive belt has come off. Open the lid. Remove the rubber mat on the platter. Remove the C-shaped clip from the center of the turntable. Lift the platter up and off. Find the flat rubber band that connects platter and the motor. Plug it in and verify that the motor turns when you press power, then standby, then phono.If the motor spins, unplug power and place the drive belt on the underside of the platter. This is not easy, but it can be done with patience. Then put the C-clip back on and replace the mat. Congrats!.
Oct 10, 2009 | Philco 841205 Turntable
44 people viewed this question
 Grubhead
Grubhead
