Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer keeps running, doesn't heat up
Possible timer problem?
  • Anonymous Apr 18, 2009
    timer advances, doesn't heat
  • Anonymous Apr 23, 2009
    Whirlpool dryer continues to run and won't dry clothes, no heat.
    Problem Solver:
  • 18 Answers
Yes. If the timer does not advance, it is a timer issue. the heat may or may not be related, try replacing the timer first.
Posted on Jan 21, 2009
SOURCE: whirlpool dryer problem
dryer works but does not heat up
Posted on Aug 11, 2008
codfish124
  • 36 Answers
SOURCE: Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Posted on Dec 09, 2008
SOURCE: whirlpool dryer: supreme Not heating up
I had the same problem I change the gas valve coils and it seamed to be working fine.
Posted on Jan 07, 2009
roniecon
  • 6927 Answers
SOURCE: Whirlpool dryer WED5300VW0 runs and heats but
The timer has gone out,replace the timer with a new one.
Posted on Oct 10, 2009
Testimonial: "Thanks"
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
I have a Whirlpool dryer, model ler5644awo.When I set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat.could it be the...
Hello, welcome to FixYa.
Based on your post I understand you have a Whirlpool dryer that you stated "
set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat", correct ?
Having said that, by far and away the most common and the first thing I'd look for on these dryers is the fuse which is located on the blower housing, not likely the timer or start switch.
**Unplug the dryer from the wall before performing any service or removing any panels...safety first**
You can use the link below for a tutorial video to locate, test and replace the fuse that is specific to your model.
**please check the part with an ohm meter or "jump it out" (if you know how, if not, check the second link it will show you) before replacing it...the timer or start switch is possible, just not as likely as I mentioned**
http://www.youtube.com/watch?v=aUQQJAxkZ0g&feature=relmfu
http://www.youtube.com/watch?v=3nicyh6EUHc
Let me know if I can assist you in any other manner going forward and I'll be glad to do so.
If this info provided solves your problem, please take a second to accept my solution and rate it accordingly. Good luck and thank you for choosing FixYa today.
Regards,
Macmarkus :)
Oct 30, 2011 | Dryers
Bought a whirlpool dryer.runs but timer doesn't work and most importantly there is no heat. what do I need to replace to fix the heating problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
Mod: LGR5620KQ1 dryer keeps running. timer stays the same.
sounds like short to ground and feed back to timer
Aug 31, 2009 | Whirlpool Dryers
Limited heat and timer not advancing
something in the vent or blower housing the reason it heats for a short time then has to cool is a possible restriction problem
Aug 19, 2009 | Whirlpool LGB6000KQ Gas Dryer
My dryer will not heat and timer works until the cooling stage
It's either the timer or insufficient air flow. check your vents to see if sufficient air is coming out.
Jul 07, 2009 | Dryers
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Dryer not heating or turning off
It can be multiple problems. First are you using it on sensor dry or timed dry? If it is timed try, it's possible your timer is not advancing. If you are using sensor dry it could be your sensor.
To test the timer, check for continuity across the timer. If it is open, replace the timer.
To test sensor, run the dryer on sensor with nothing in it, if the timer advances quickly, the sensor is not the issue. If it does not advnace, it could be the sensor.
The no heat issue; check to make sure you don't have a blockage in the venting or in the dryer. If there is no blockage, check your element. To check if the element is not heating up, check for continuity through the sensor.
Hope that helps.
Nov 16, 2008 | Whirlpool LEB6200 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
359 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
