Question about Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat
Rinnai EnergySaver 308FTR Turning off
Our heater is turning off after about five minutes. We have two timers on the heater. We have tried turning it off to reset the timer. Not sure if it is to do with this, any help would be appreciated. It's freezing! Thanks, Georgie
You can read the heater's error messages from its internal memory - that should help. See page 32 of handbook (link above). Peter
Posted on Jul 27, 2007
A dirty filter will cause shut-off: is the FILTER lamp alight? Vacuum clean the filter if necessary. Are you sure you've set the timers properly? What temperature is set? LH figure is the desired temperature - RH side is temp measured by thermistor inside unit. If set too low, it turns heater off. Download the 308FTR manual here:http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/220.pdf Regards - Peter
SOURCE:
Would like a manual for the rinnai energysaver 403FT we need to set our heater up so it goes on auto and how do we regulate the temperature and set time
The model number (403FT) has either been discontinued, changed or is incorrect. However, Model # RHE309FT closely matches the heater you described and has the timer and temperature features you are wanting to preset.
You may download and print the manual from the link below for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_Energysaver_RHFE309_559FT.pdf
Hope this helps you and thanks for choosing FixYa. Cheers
Aug 15, 2011 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
How to set timers
Here is a link to the manual for the 1004 FTR that has the timer. Hope this is right one for you. Re-post with your exact model if this doesn't help. I check in most days and can help with links to most manuals
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/1004FTR.pdf
Aug 18, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
Where is the pilot light on Rinnai EnergySaver 1001F
If you smell gas in a Rinnai you have a big issue. This heater is what is called a direct vent heater with an electronic ignition so the combustion chamber is sealed and the smell of gas is an indication that you have a gas leak. Please call a professional today.
Oct 13, 2009 | Rinnai Heating & Cooling
I have a Rinnai 308FTR heater and the first time I
Means failed ignition/no gas.
Check gas supply.
Mar 05, 2009 | Heating & Cooling
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat Logo
338 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Sheldon Dedek
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
