Crafts & Hobbies Logo
Anonymous Posted on Jan 10, 2013
Is it best to use a wooden splint to spread glue onto wood?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
Helped
5693
Points
39
I used to use one until I read this tip: http://woodgears.ca/shop-tricks/glue_spatula.html
Now I use a spatula and it is incredibly easy to clean afterwards.
What type of wood is used in wooden pallets?
There is a wide range of wood species available that is best suited for different purposes. Hardwoods were mainly used in ancient time for building pieces of furniture. Whereas softwoods are used for many other purposes. Pine is considered to be the best wood for designing pallets. You can check Palletower to get some more idea about the different types of wood.
2answers
How do I fix a broken toilet seat?
Toilet seats are often found very durable in designs and most of them are made of wooden or particle board to solid wood. Also padded seats are just a padded induced on wooden seat by any adhesive solution. So, its normal to find crack or patch on a toilet seat after long use or by any accident, which also can be repaired by you without any specialized knowledge. You will not need any advanced tool but Basic DIY tools .
Let see the step by step method of fixing a broken or cracked toilet seat:
Step 1: At first remove that cracked toilet seat from the toilet fixture by unscrewing the seat screws using a flat screwdriver.
Step 2: Spread the crack slightly and push wood glue or wooden adhesive solution inside of it. Make sure the glue coated entire inner surface of the crack.
Step 3 : Squeeze the seat together you can use bar clamp. Wipe out any excess glue on the outer surface of the crack
Step 5 : dry overnight or minimum 6 hours and re-install it.
Note: if you find it's cracked or split heavily , or if it is pinching your back. Or if it seems nasty to look at then think about it .Toilet seats are pretty reasonable, so price shouldn't be an issue. If you don't want to look at the nasty underside, get rid of it and replace with a better one.
This toilet guide will provide you all kinds of essential information about toilet and bathroom fixtures,product reviews , expert's recommendations .
Take what you need and Do it Yourself.
Apr 05, 2018 • Home
1helpful
What would be the best way to fix a metal plate or trim on the outside of a wooden patio door?
2 part epoxys work very well . it will say wood metal plastic and bonds in around 5 minutes.
3answers
How can I build wooden model airplanes?
There are many kits available across a wide range of prices. Then, if you want a flying model, that's a level further. Good kits come with good instructions and fit together well, so look for a name brand until you have experience and can cope with the tough ones. Start easy and work up.
Try a good hobby store in your district or
http://www.guillow.com/modelkits.aspx
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2053587.m570.l1313.TR3.TRC1.A0.H0.XWood+Model+Airplane+kit.TRS0&_nkw=Wood+Model+Airplane+kit&_sacat=0
Aug 15, 2015 • Toys
Need to glue some joints in the drawers of my wooden/cardboard dresser
yes it would need to be removed ,,, scrape of the excess and use a low grit sand paper to make it quicker ........ usually how wood joints work is the glue makes the male joint expand inthe female joint making a very strong bond . for this you need to make sure all old glue is removed so the wood is exposed again so the glue can be absorbed into the wood ... pva glue works well , ask at your diy store they will be able to suggest a good adhesive. if you dont want to clean it maybe a modern adhesive like no nails may work too .... good luck
Mar 29, 2014 • Furniture
Wooden clothes rack shaky
Check the rods to see which are loose and add a tiny amount of wood glue if its possible. Remember put it in the hole where movement is not required for folding and putting away into storage. hope that helps.
Need to paint for my garden sign, its in wood and is there any suggestion?
its best to prime any wood before painting and use a good oil base exterior pant
2answers
Toy wooden castle, broken apart. Clean break. What is best adhesive to reattach?
Elmers wood glue with compression during curing. Note this is not white glue and it is sometimes called carpenters glue
Nov 30, 2012 • Toys
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
