Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
WTW6800WW1 won't dispense fabric softener - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 209 Answers
SOURCE: water in softener dispenser
the conditioner works by siphoning out when the water from filling mixes with it, the excess water then drains away the same way, when you took the drawer out, you must have either not cleared all the powder or not put it back together properly, if it worked before it has to be something you have done, sorry, just keep trying different ways and double check to see if all bits have been cleaned properly if i have helped please rate me
Posted on Sep 17, 2007
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
SOURCE: whirlpool washer fabric softener dispenser
The fabric softener dispenser in my Whirlpool washing machine is caked w/hair and detergent. I have tried to take it out by unscrewing it, but it won't come out. What's the secret? Please help!
Posted on Sep 20, 2009
  • 129 Answers
SOURCE: Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Posted on Feb 04, 2010
  • 56 Answers
SOURCE: Cleaning Fabric Softener Dispenser
it does come apart it is stwited in from the bottom up . but you can soak it in some hot water and shake it it will come clean after a bit
Posted on Jun 02, 2010
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Front loader. Why doesn't fabric softener dispenser empty?
It can be two things. First, what is left in the dispenser? If its the fabric softener, then the water valve may be faulty. The water valve will have multiple feeds and the fabric softener might be bad. If its a combination of water and softener, then the dispenser might be clogged. You can remove the slide out tray and clean it. Look for build up of fabric softener that might be there. Good Luck?
Nov 23, 2015 | Frigidaire Washing Machines
Frigidaire gallery washer
code f 21 mattag 3000 series f21 when goes from 11mins it comes up every time can you help me out thanks
Jul 27, 2013 | Washing Machines
Kenmore frontloader fabric softener dispenser is clogged
There should be pins located somewhere on the dispenser or a grey thing located inside the dispenser, push it down and that will release the dispenser from the washer. Afterwards you can put in in the dishwasher, this should clean out any clogging residue.
Mar 10, 2013 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener will not dispense in my Gallery front load washer. I've cleaned everything I can get access to and it still won't dispense the softener
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 13, 2011 | Frigidaire Washing Machines
I just moved into a condo that has the whirlpool #LHW0050PQ front load washer and when I arrived at the condo, I found that the fabric softener tray was clogged. It has fabric softener in it that...
The dispenser asm. has a tab in the rear of it,find it and push it and the dispenser tray will pull out to be soaked and cleaned in the kitchen sink. vinegar could soften it up before going at it with a soft scrub brush.
I hope this has helped you,
Gene
Aug 04, 2011 | Whirlpool LHW0050PQ Front Load Washer
#1The fabric softener dispenser won't drain.
Make sure the dispenser is clean and free of debris inside the containers. You may have to take the dispenser apart and clean it out in the sink.
Jun 23, 2011 | LG WM1814CW Front Load Washer
We have a pin trap problem. The outer cover comes off exposing a plastic white facing that will not budge. There is constantly a rotten egg smell coming form the washing machine. I've drained the hose...
Here's How:
  1. Exterior
    Wipe down the exterior of the washing machine with vinegar or your favorite all-purpose cleaner.
  2. Tub
    Pour two cups of vinegar or lemon juice into the tub, and run the washing machine through a complete cycle on the hottest setting to remove odors, stains and detergent build up.
  3. Lid/Door
    Scrub around the edge of the lid/door with vinegar to remove mildew and detergent build up.
  4. Bleach and Fabric Softener Dispensers
    Remove the bleach and fabric softener dispensers, and scrub them in the sink. Then, dry them thoroughly and return them to the machine.
Tips:
  1. To prevent mildewing, leave the lid open after you finish a load to allow the washing machine to dry out.
  2. Commerical fabric softeners leave build up in the machine. of choice, and the inside of your washing machine won't need to be cleaned as frequently - if at all.
May 17, 2011 | Asko W6021 Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
