Question about Canon PowerShot S2 IS Digital Camera
Fill-in flash Probably a basic question : how do you use flash fill-in on this camera ? (force flash in high-light conditions)
    Genius:
  • 2,985 Answers
Then manual should tell you - have you looked?
Posted on Jul 02, 2007
SOURCE:
Sony Cyber-Shot DSC-P73 Digital Camera suddenly flash is not working
The flash may be broken.
If not these are the flash settings on the camera in case a different flash mode has been set accidently.
Set the mode dial to [camera icon], and press [up arrow] on the control button repeatedly to select a flash mode.
The flash mode has the following features.
No indicator (Auto):
The camera decides to use the flash based on lighting
conditions. The flash will be used when
there is not enough light or when shooting a
subject against a light source.
(Forced flash):
The flash will be used regardless of the amount of ambient light.
(Slow synchro):
light. In this mode, the shutter speed is
slower under dark conditions, so you can
clearly shoot a background that is out of the flash-lit area.
(No flash):
The flash will not be used.
Oct 18, 2014 | Sony Cyber-Shot DSC-P73 Digital Camera
Fill flash
Press cursor-up (marked with a lightning bolt) to cycle through the various flash modes. For fill flash, select the lightning bolt without the letter "A" to force the flash to fire. See page 8 of the Basic Camera User Guide http://gdlp01.c-wss.com/gds/2/0900001192/01/PSA540_530CUGba-EN.pdf
Apr 26, 2013 | Canon PowerShot A540 Digital Camera
How do i turn the flash off
Welcome to FixYa.
The FORCED OFF mode is the setting where flash is not activated in any recording condition. this mode used when taking pictures in places where the use of the flash is not permitted.
There are other 5 different mode/setting in using photo flash.
1. AUTO - flash automatically activated according to the recording condition.
2. AUTO/Red-eye reduction - flash is automatically activated according to the recording condition. It reduces the red-eye phenomenon by triggering the flash before actually recording the picture. After that, the flash is activated for actual recording again.
3. FORCED ON - use the when your subject is back-lit or under fluorescent light.
4. FORCED ON/Red-eye reduction - use this when you set the camera to PARTY MODE
5. Slow sync./Red-eye reduction - use this when you take pictures of people in front of a dark background.
I hope this solution will help you. Just send us you comments or suggestion if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
My sony DSC H10 cameras flash isnt working what could it be?
If the flash is not functioning, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
This should resolve the issue.
Thanks for using FixYa.
Jan 27, 2011 | Cameras
My camera flashes lightnot working how can i fix it?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
Jan 16, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I can't figure out how to set my flash to "force flash" aka fill
Turn the setting to M or manual, and push the flash open. You will have to set the camera settings yourself though.
Apr 29, 2009 | Nikon D40x Digital Camera
I CAN'T TURN ON THE FLASH.WHY? AND PICTURES LOOK BLURRY.HOW DO I ADJUST THAT?
usually by manually over-riding the automatic flash, the shutter speed varies (in this case it slows down, giving you that blurry or ghosted look) depending on the lighting conditions. If you are shooting in the dark (with flash), leave the flash on automatic. Only force the flash to fire manually if you are shooting in bright conditions, as a "fill-in" flash to reduce shadows.
Feb 27, 2009 | Vivitar ViviCam 6330s Digital Camera
Camera won't take a picture
WHAT YOU ARE SEEING IS BASICALLY AN ERROR WARNING THAT THE SHUTTER SPEED IS NOT RIGHT FOR THE LIGHT CONDITION AND THE LIGHTNING BOLT USUALLY MEANS THE FLASH IS NEEDED. IF THIS IS A FILM CAMERA, IT IS PROBABLY WANTING YOU TO PUT IN THE CORRECT EXPOSURE SETTINGS FOR THE CONDITIONS. DOES THIS HAPPEN WITH ALL CONDITIONS? HAVE YOU TRIED OTHER SETTINGS ON THE CAMERA? LET ME KNOW IF YOU NEED MORE HELP.
ARCLIGHT1217
Nov 03, 2008 | Nikon N5005 35mm SLR Camera
Taking pictures with low light
on the top dial position to p........ if neer a window during daylight dial to gide and select shooting into backlight then over to fill in flash.........also indoors and portrit with flash helps
Dec 13, 2007 | Olympus SP-510 UZ Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
