Question about Dryers
I just received my new kenmore elite dryer model #796.6151 and it wont heat up..i already performed the heating test and made sure the gas valve was open and it still doesn't work what should i do next
2 Suggested Answers
SOURCE: Kenmore 70 Series
Unplug and turn off the gas feed. The fuse is located in the back of the series 70 attached to the lint housing near the bottom. About 1-1/2 inches long. Easy to remove, only two contact wire attachments. Note which wire goes where. Under $10.00 at an appliance parts store. Start with this fix.
If still no heat take out the ignitor assembly, located in the front, lower left. It is attached to the base of the dryer by 3 screws, the gas feed and two electrical wires with removable metal attachments (note which attachment goes where). The entire assembly will come out and the ingitor is attached to the front end. I took mine to the appliance parts store and it tested OK so it was the fuse. The owner helped me locate the fuse and suggested I try this first. The ignitor coil is about $25.00.
Both of these were easy enough for a novice (like me) to do. It saved a lot of money.
While the dryer was open I vacuumed out all the dust and lint and checked the integrity of the belt.
Good luck.
Posted on Oct 07, 2008
He3 gas dryer not heating
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
Kenmore elite gas dryer won't heat.I tested thermal fuse, high limit thermostat, thermistor and gas valve. All within spec or have continuity.
Hello Chuck,
In addation to what you have checked here is a list of what else to check
Flame switch...black box on burner tube...check for continuty
Ignitor...check for 120 vac too it
Timer/control board heat relay..on models w/timer check for contunity in heat circuit on timer. ON models w/control check that heat relay on board is closing and has continuty
Motor switch..check that heat circuit is closed and has continuty when motor is running and motor switch has closed for heat circuit(the start winding switch on motor will be open when running)
WARNING..WHEN PLUGGED IN FLAME SWITCH WILL BE LIVE ALL THE TIME AND SHOCK YOU WHEN TOUCHING..BE SURE TO DISCONNECT POWER BEFORE CHECKING
Gene
Aug 09, 2011 | Kenmore Dryers
Kenmore Elite model #110700932990 dryer has no heat
My experience has been that most of the time when a gas dryer does not heat, that the igniter has gone bad...
The other less common problem is that the coils of the gas valve go bad...
Other problems can be the thermostat, the high limit, or the thermal fuse going bad...
Here is a tip that I wrote about not heat in gas dryers...
gas no heat tip....
heatman101
Nov 23, 2010 | Kenmore 74642 Gas Dryer
I have a model 110.92832100 Kenmore Elite gas dryer that has stopped drying. i found a penny welded onto the Thermal fuse, so I replaced it and while I was in there I replaced the thermostat. When the...
Since you are already this far you have some knowledge of how you dryer works. What is wrong now is the heat sensor that picks up that the pilot is on. The pilot should burn at a steady flame when you turn the dryer on to heat this in turn heats a probe next to the piolit this is a type of heat sensor. When the probe or heat sensor senses heat it tells the gas valve that its okay to turn on. Have a great day and hope this helps.
Aug 19, 2010 | Kenmore Dryers
My dryer (kenmore elite model 110.64992300) wont heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 26, 2010 | Kenmore 64992 Electric Dryer
Kenmore Elite 110.7208201 won't heat up.
Hi
Please check the things that could stop a electric dryer from heating:
- House fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
And also check the things that could stop a gas dryer from heating if you have a gas dryer:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | Kenmore Dryers
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore elite smartheat quitpak electric dyer
Hello talee725. the dryer has heat sensors located throughout. One at the air intake & exchaust of the heating element including the air exchaust of the drum. Disconnect the AC power, close the gas valve is gas powered, clean them and check the sensors with a DVM in the ohm scale for open ckt. They are usely round in shape with 2 wires connected. If test open call a local appliance parts/repair center for price and stock.
Nov 05, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dryer model#73022 no heat when running
The first thing is to look at your tech manual and do a continuity test on the thermistor.
Oct 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Aug 10, 2008 | Dryers
Dryers Logo
167 people viewed this question
Top Dryers Experts
