Need good php editor
Hello
I need a good php editor which contains Internal preview (preview)
I'v tried Dev php but i dont like it plz help i will rate your solutions.
Thank you
  • 32 Answers
Try eclipse with pdt: http://www.eclipse.org/pdt/
It has a lot of features incl. code completion. I used it for professional work and I was really happy with it.
Posted on Oct 12, 2009
Need Ep 9gf6100-M drivers pLz help!
Hello try the drivers here from biostar:
http://www.biostar-usa.com/mbdownloads.asp?model=TFORCE%206100-939
The drivers should match your mainboard.
But do not install the 64 bit driver unless you run this system.
You maybe have to unzip the file before you install.
Here is others with the same chipset:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=164#dl
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=189#dl
Good luck
Dec 24, 2012 | Computers & Internet
Is it possible to access the whole C drive when using Ubuntu?
What Can Be Mounted
The most common thing to be mounted is a hard drive partition. Hard drives are kept in /dev and have different names depending on what type of drive they are. IDE/ATA drives are labelled as /dev/hda, /dev/hdb, /dev/hdc and /dev/hdd (since a PC's IDE interfaces can only handle 4 devices at a time). Note that these can be devices such as IDE/ATA CDROMS, Compact Flash to IDE converters, and some special floppy drives (although they tend to appear mainly in laptops). For SCSI devices the labels are /dev/sda, /dev/sdb, /dev/sdc, /dev/sdd, /dev/sde, /dev/sdf, /dev/sdg, /dev/sdh and /dev/sdi (since a SCSI chain can contain up to nine devices). Other types of drive, such as USB, SATA, etc. are mapped to these SCSI devices by Linux. Therefore SATA and USB drives are labelled as /dev/sdX where X is a letter, starting at "a".
Since these are literally the devices you can issue a command such as:
sudo eject /dev/hdc
If /dev/hdc is a CD drive then it will eject.
In the case of hard drives, there is another abstraction. A hard drive (and many devices such as USB "sticks" which act like hard drives) can be partitioned to allow many filesystems to be stored on them. This means that the filesystems themselves are accessible via the partition labels, such as /dev/hda1 (the first partition on /dev/hda). This means that we finally know about something we can mount, a partition, since it contains a filesystem.
Another physical filesystem which can be mounted is the ISO9660 filesystem used on CDROMs. Since there is only ever one CD in a CD drive there is no point creating /dev/hdc1 (where /dev/hdc is a CDROM drive) since there is only one filesystem on it. That means that you can mount CD drive devices explicitly, so if /dev/hdc is a CDROM drive then it is possible to mount /dev/hdc if there is a disc in it.
Floppy disks only contain one filesystem, and are labeled as /dev/fd0 for the first drive, /dev/fd1 for the second drive, etc. So now we know three things which can be mounted.
Devices like USB sticks are treated like hard drives (so /dev/sda1, for example, may contain a filesystem) and so are iPods (although I think the main data on an iPod is stored on the second partition)
Mounting is not restricted to physical devices. If you have a filesystem "image" (which IS a filesystem, whether an exact copy of an existing filesystem, or a filesystem created specifically for that file) then you can mount that through the use of a fake device called the "loopback device"
How To Mount/Unmount Filesystems
Unmounting
Firstly I will tell you how to unmount any filesystem you mount after trying these commands. Unmounting is done through the "umount" command, which can be given a device or a mount point so:
sudo umount /mnt
sudo umount /dev/hda1
Would both unmount the filesystem on /dev/hda1 if it is mounted on /mnt.
Remember that a filesystem cannot be in use when it is unmounted, otherwise umount will give an error. If you know it is safe to unmount a filesystem you can use:
sudo umount -l /mountpoint
Sep 23, 2011 | Microsoft Computers & Internet
I need a user/operaing manual for a Pioneer PD F19 CD Player
yes
What Can Be Mounted
sudo eject /dev/hdc
Unmounting
sudo umount /mnt
Sep 23, 2011 | Cameras
I have an iomega lphd-up external drive it was working fine now it is saying that it needs to be fomated plugged in to several laptops i get the same message. i dont wanna lose the content. what can i do?
Try getting a live cd (such as the system rescue cd). Burn the .iso file to a disk, then boot from the CD by hitting a key at your BIOS menu (usually F1 or F9) to bring up the boot menu, and select CD. Once you've booted and you have your prompt, plug in your external drive and try the following commands:
fdisk -l (that will show you all the disks attached to your computer. Typically the first disk [internal] is sda, and the USB disk is sdb.) The thing to take note of here is the last column on the list that contains /dev/sdb#, it should say NTFS, or FAT32, or something like that.
fsck /dev/sdb1 (that will check the file system on the first partition on your external drive. If it comes back with an errory, try fsck.NTFS or fsck.FAT32, whatever the file system was in the first part.)
testdsk /dev/sdb (That will initiate a harddrive test that could find/fix errors with your drive).
If none of that works, plug in another drive to make a backup of your external. Take note that it's important to have free space on the SECOND (not broken) external that is EQUAL TO or GREATER than the amount of USED space on the broken drive.
Once the backup drive is plugged in, type mount /dev/sdc1 /mnt/backup (if that doesn't work or it says something about NTFS and read only, type umount /mnt/backup; ntfs-3g /dev/sdc1 /mnt/backup).
Finally, type mkdir /mnt/backup/SDB to make a directory to store the files.
Now with the second drive, try to mount it using the advice for sdc (although change /mnt/backup to /mnt/windows)
If it mounts, then type rsync -av --progress /mnt/windows /mnt/backup/SDB/ which will start copying all the files onto the backup drive. NOTE: This will cause a lot of text to scroll, and will take a long time!
Once that's finished, you can restart into windows and format your drive, then plug in the extra drive and copy everything back over.
Hopefully that helps!
Jul 20, 2011 | Computers & Internet
Hello sir when switch on my mobile it need restriction code and i also dont have security code of my mobile plz help me ...
hello sir when switch on my mobile it need restriction code and i also dont have security code of my mobile 3110c imei 353225036074421 plz help me ...
Dec 15, 2010 | Nokia 3110 Cellular Phone
How to removed rvhost.exe virus? i was not able to open my registry editor, ''regedit'' prompts error upon opening.
Hello
You will need to stop the program first and then run several command line commands to re-enable the Registry Editor
http://www.antivirusworld.com/articles/virus/autoit.php
This link has all of the directions.
Good luck.
Dec 03, 2009 | HP Computers & Internet
Hello, how do i replace the developer in my sharp ar407 copier? please help me!
http://www.eserviceinfo.com/download.php?fileid=41998
Hi ,i uploaded the service manual at the above link in 3 sections.Download all 3 sections before unzipping it and it comes in pdf format.The dev section is on page 4-6 if i am right.good luck and let me know.
Jun 23, 2009 | Sharp AR-407 Copier
Best php editor
Yes. This is a good place to start for comparing PHP editors.
http://en.wikipedia.org/wiki/List_of_PHP_editors
Please let me know if you have any other questions.
Thanks, Raph30
Jan 21, 2009 | Computers & Internet
Preview image scrambles up during editing with Ulead and Movie Maker
hi dear
if you using Ulead video editor versi 7.8. 10 and 11
it's scrambles when preview,
use a Ulead Video ed. versi 9.0.
it's oke to see realtime video preview.... i have to try that
i hope this solved your problem
thx
cropp
Mar 10, 2008 | Ulead VideoStudio 9
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
