Shorted mosfet and transistor plus 4 burnt resistors
I HAVE A LG910 MONITOR WITH SHORTED FQPF19N20C MOSFET(Q719) AND TRANSISTOR(Q702) ALSO 4 BURNT RESISTORS
CANNOT TELL THE VALUES. PLEASE IF POSSIBLE ANY FURTHER
CHECKS I HAVE TO DO IF NEW PARTS ARE FITTED.THANKING YOU
  • 4 more comments
  • drmakangee Feb 04, 2009
    ON THE LG 910 I NEED TO KNOW THE VALUES OF THE 4
    BURNT RESISTOR SURROUNDED BY Q719(MOSFET FQPF19N20C)AND Q702(TYPE OF TRANSISTOR)AND WHAT FURTHER CHECKS I HAVE TO DO BEFORE NEW PARTS ARE REPLACED
    WHAT REPLACEMENT CAN I USE FOR THE MOSFET FQPF19N20C
    WHAT SUBSTITUTE CAN I USED FOR MOSFET(FQPF19N20C)
    PLEASE GIVE ME I LIST OF SUBSTITUTES THANK YOU
    ANYTHING IN THE BUK OR SK OR STP RANGE I CAN USE
    IN PLACE OF FQPF19N20C WHICH IS EASILY AVAILABLE
    IN MY AREA THANKING YOU
  • drmakangee Feb 05, 2009
    IS THERE NO OTHER EQUIVALENT FET THAT I CAN USE
    INSTEAD OF FQPF19N20C BECAUSE I AM REALLY STUCK
    AND BY THE WAY THANK YOU VERY MUCH SEEMS TO ME
    I HAVE COME TO A DEAD END.AS THE SUPPLIERS IN
    MY AREA HAVE NOT HEARD OF THIS PART
    THANKS
    SOLUTION HELPFUL ONLY PROBLEM IS GETTING THE CORRECT
    SPARES. THANK YOU VERY MUCH
    Sergeant:
  • 326 Answers
Manufacturer Part Number ---------FQPF19N20C.
Description -------------- MOSFET N-CH 200V 19A TO-220F.
Vendor ----------------Fairchild Semiconductor
MOSFET N-CH 200V 19A TO-220F - FQPF19N20C
Order 'mosfet n-ch 200v 19a to-220f - FQPF19N20C' online from Digi-Key. Manufactured by Fairchild Semiconductor. Digi-Key part number FQPF19N20C-ND.
Posted on Feb 04, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi.. u first check out the board completely
and replace the items which have got burnt,
make sure that u are replacing it with the
correct values,it willdefinitely.
This will solve ur problem.
thank u..
  • Hariharanath V Feb 04, 2009
    hi..try to change it with the correct values,
    it will definitely work.
    thanks..
    hi..try it out with IRS950 MOSFET.
    this may be equivalent to FQPF19N20C
    MOSFET.This may solve your problem.
    thank u..
  • 15,935 Answers
Any one with THESE scecifications
  • blueextc3221
    blueextc3221 Feb 04, 2009
    FQPF19N20L should also work
  • blueextc3221
    No, the rest of the logic relies on the specs of that specific one!
  • 916 Answers
The resistors you need are is 27 ohms, 1 Watt, flameproof
  • machadojr_fe Feb 04, 2009
    To use different mosfets you will have to redesign the entire
    voltage regulation. You have to match everything up and position it
    all correctly. You will need to replace it with the same kind that you have now.
    you need to replace it with the same or equivalent mosfet so you will need to call or email LG. Here is there contact info for you.
    Contact by E-mail: customerservice@lge.com
    Contact by Telephone Toll Free: 1 (800) 793-8896
    LG Electronics
    201 James Record Rd
    PO. Box 240007
    Huntsville, Alabama 35813
  • 362 Answers
Hi drmakangee,
If you are still able to see the colors of the resistors here is a color chart and calculator I use.
http://www.csgnetwork.com/resistcolcalc.html
This should help with Transistor ID:
http://electronics.wikia.com/wiki/Transistor
If you can please post a digital photo of the components so we can help with ID.
Lone99star
  • 495 Answers
shorted mosfet and transistor plus 4 burnt resisto - moz-screenshot.jpgmoshorted mosfet and transistor plus 4 burnt resisto - moz-screenshot-2.jpgclass=moz-screenshot-2.jpgQ702 : Value is VSTDTC114ES--RP
Q719: Value is VST2SB861C
  • 1 more comment
  • Manoj Rout
    Manoj Rout Feb 04, 2009
    Go to this link for replacement procedures
    http://cardi.igeofcu.unam.mx/techdocs/Mo...
  • Manoj Rout
    My sincere advice to you would be to contact your service dealer before any replacement.
  • dtvjho
    dtvjho Jan 27, 2011
    Link is not working as of Jan 2011
    Master:
  • 848 Answers
the value of resistor is 0,27 Ohm/2W.......
    Genius:
  • 1,913 Answers
Check on circuit bord u found burnt part on that change that parts.
  • 19,396 Answers
I see if I can find schematics online, otherwise you will have to purchase the service manual.
I've replaced the mosfet rjh3047 because short-circuited. the new one is gone as well shorted. thing else I can check?
you must have some diagram b) must test some around components like capacitor+diode+resistor+ic+Trafo , that will be in short circuit this will provoke the short in your MOSFET transistor.
God bless you
Oct 15, 2012 | Samsung LJ92-01393A BN96-04594A...
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
Burtn out resistors on a quantum audio q 700.1
The resistors are probably burnt because of the audio mosfet transistors going out. you will have to test them with a meter. don't just replace the resistors, they will burn up again and maybe cause more damdage
Jan 29, 2010 | Car Audio & Video
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
Jan 07, 2010 | Computers & Internet
Power up problem with alesis rs300 (ra300)
you have more than likely damaged some transistors.
the resistors have burned because of excessive current.
there are 2 typesof transistors,bipolar and mosfet
a bipolar transistor has 3 pins.1) base 2)emitter 3)collector.
an NPN is tested with the + meter lead on the base , and a PNP transistor with the - lead on the base.
TESTING
base to collector should read .5 to .6 v drop in one direction and open in the other with a digital meter on the diode check function.
base to emitter about the same,but slightly higher than the collector.
if base to collector is .5v then base to emitter is .52 or so.it is always higher than the base collector number.
between emitter and collector will read open in both directions.
if there is a short on any lead combination,the transistor is blown.
npn transistors operate on the positive rail power supply,and pnp on the negative rail.
typically a 150 watt amp will run + - 65vdc.
the transistors running on the plus side are npn and on the negative pnp.
most pnp output transistors are green.,but some are black,
so we must go by the numbers on the transistors, eg.A1076 is a pnp,B755 is a pnp and all transistors that have a C or D eg. D424 are NPN transistors. all A and B numbers are PNP and all C and D numbers are NPN.
MOSFET transistors have 3 pins 1)gate 2)drain 3)source
the source goes to power like the collector does. the drain is like the emitter,and the gate switches it on like the base does.
testing a mosfet is a different procedure.
a mosfet with k then a number e.g. k135 is a positive device like npn.
a mosfet with j and a number e.g. J50 is a negative device like pnp.
a mosfet reads open source to drain both directions.
for a positive (k number device) the plus meter lead goes on the source.,the black meter lead on the drain. on the diode test function.
jump a wire from the source to the gate for 1/2 second and remove the jumper while leaving the other two meter leads connected to the source and drain.The mosfet should switch on and the meter should show a short.that means the mosfet switched on.About 5 seconds later,the resistance from drain to source should go open.
for a p channel mosfet,it checks the same,except that the black meter lead goes on the source and gate .
a mosfet will stay switched on longer than the voltage applied to the gate,if it is driving a high impedance device such as a meter.
a bipolar transistor will not stay on when voltage is removed from the base lead.
i hope this has been of some help.
Sep 09, 2009 | Alesis RA-150 Amplifier
Benq 737s monitor black screen
BenQ LCDs are known for poor solder connections causing the inverter driver transistors to short.
Result is no backlight.
Monitor Mike
Jan 03, 2009 | BenQ FP737S-D 17" LCD Monitor
How can i open mylg e700.
I have repaired various LG monitor & they all seem to suffer the same problem with the led flashing. The fault is fixed by replacing Q719 which is a Mosfet IRFS640 & C744 100uf100v cap, also check caps in power supply a couple of 220uf63v pop from the bottom. I have had the line output transistor s/c.If its the one Im thinking of, to take the back off . Tip the screen on its face & with a pair of long nose pliers wedge them into the clip at the bottom & use a flat blade screwdriver to prise the bottom slightly away. Then place the monitor upright using your screwdriver you have to pop the top. Push 2 inches from each corner. You have to push hard. Good luck.
Jun 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor diagram
www.servicing-manuals.com
Jan 30, 2008 | Video Game Consoles & Games
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
Computers & Internet Logo
259 people viewed this question
David Payne
David Payne
