Question about Toshiba Satellite A215-S7422 Notebook
Toshiba Satelitte VGA problems
Recently, my screen to my Toshiba Satelite A215 broke, apparently carrying around a screen in my backpack cracked the screen on the left side. I'm not really concerned about that, I'm resigned to the wear and tear of it all. As a temporary fix, I bought a Insignia (Bestbuy cheap knock off kinda TV) that has a VGA plugin. It works while starting up just fine. Once it hits the Windows vista part though, I lose the signal entirely, and I can't do anything. I mean... I can, but I have no screen to tell what I'm actually doing.
I know the VGA slot works because of it working on startup. I can also use the screen just fine when I'm in safe mode. I'm baffled at what to do, as I can't do much of anything with the screen turning immediately off when I am not in safe mode. My screen on my laptop is as noted before, pretty much broken entirely, and only is a basic white when turned on, and you can make out a tiny bit of the picture, but not enough to really change the settings around to use a different monitor. Safe mode works just fine, but I can't really... change any settings in it that I can see. It's pretty frustrating, any advice?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Friend which problem you are facing it is because of three resons.
in toshiba genrally
1. after hit on windows vista for external vga you have to press FN+function key again where moniter or lcd symbol displayed.
2. vga settings in oprating system not compatiable with external moniter.
start system in safe mode change setting at minimum requerment of vga ,save it and restart in normal mode.
In xp you can use F8 at start up and select vga mode.
3. this is related to hardware:
some of the toshiba laptops vga graphics chip is dry solded
by that it run oprating system in safe mode fine.
but extended vga mode or in normal mode not give resolution or some time patches on screen.
For that you have to change vga chip .It is bettr to take it to the service station.
Posted on Jan 21, 2009
  • 41 Answers
Turn the computer on and straight away start tapping F8. When you get the advanced boot options choose low resolution mode or VGA Mode. When windows loads up your graphics will look really bad but you can sort out the resolution from control panel.
My Toshiba A215-S4697 froze and I shut it off by holding the power button down. When I went to turn it back on the power light came on but the Satelitte light didn't. The screen wasn't on either and the...
it could have failed,but its more likely you have sequential procedures for the power button,like holding it down for more than 5 seconds etc--you might have just put your machine into "standby mode"--check manufacturers site for power key process--good luck!
Davey snake!
Oct 17, 2010 | Toshiba Satellite A215-S4697 Notebook PC
My toshiba satelite is A215-s4747 the problem I
Have you tried installing the latest Chicony Webcam driver software from your Toshiba product home page?
latest is version 1.7.231.1126
Download it, right click the file - select compatibility tab and check the following settings
then hit ok and install as usual
=======================MENTOR======================
May 15, 2010 | Toshiba Satellite A205-S4617 Notebook
Video controller for Toshiba A215-S5815 laptop
try the toshiba web site or go to www.softwarepatch.com/
and see if theres a video driver you can download.
hope this helps.
Apr 26, 2010 | Toshiba Satellite A215-S5815 Notebook
Mar 27, 2010 | Toshiba Satellite A205-S4617 Notebook
Toshiba satelite isn't recognizing that the
Have you tried using a different mic? If its a cheap mic It may have very well just quit working(or never worked).
Is it a new laptop? If not, any previous issues/problems?
"Apparently" the drivers are updated? "Apparently" isn't exactly a good term to use when it comes to something like drivers. Its either: Yes, they are or No, they are not. Make sure they are first.
To test if the mic is/isn't working go to Control Panel> Sounds and Audio Devices>Advanced Button(Bring up the Mixer)>Properties>Make sure Mic is checked in the list. Go back to the mixer, and un-mute the mic and slide the volume bar all the way if it isn't already. Now talk into the mic, is it playing threw the speakers? Yes? No?
From what you've provided I would guess its just a bad/broke mic. I'd suggest investing in something better, like a headset with the mic built in(as you'll probably need one at some point anyways).
Oct 22, 2009 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Karaoke
hi, you can connect a video monitor or beam your laptop with the external VGA output fn + f5 and you can select the preferred output, but everything you do on the laptop, will appear in another screen
Mar 13, 2009 | Toshiba Satellite A215-S4747 Notebook
TOSHIBA SATELITTE A215-S5800
good day fixya,
I found the solution on the problem, I downloaded Toshiba's ACPI Flash BIOS ver 1.70 at TOSHIBA.COM, services and support. Thanks
pjaugan
Apr 11, 2008 | Computers & Internet
Toshiba Satellite A215-S7422 Notebook Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
