Question about Toshiba DVR610 DVD Recorder/VCR
Need an RCA Adapter for a TOSHIBA D-VR610KU
RCA adapter that will fit on the male end of my coaxial cable. The adapter needs to fit into the RCA port (female) on the DVD/VCR
  • Toshiba Master
  • 19,396 Answers
The best way to do this is to buy a rf inverter at wall mart they cost under $20. It will allow you to plug in many items to run through your tv.
Posted on Jan 21, 2009
  • 356 Answers
Hi bray1262, I will be happy to help.
Here is a link to a high quality cable.
http://www.homenetworksupply.com/products_details.aspx?product_id=5109157386&zmam=17011041&zmas=1&zmac=30&zmap=144SLC1855FP2MC3BK
You can also get a cheaper one at a local electronics shop, eg: Radioshack Let me know if you need further assistance, please rate this solution.
Lone99star
  • 837 Answers
You need to use an RF adapter. This is a box that you connect your RCA plugs into the inputs in the back of the box and then connect a coax cable from the RF output to your TV. It is a powered adapter that not only converts the physical connections from RCA to coax, but also converts the video signal to RF. This is the only way you will convert RCA to coax and get a video signal.
  • Jay Glendenning
    Jay Glendenning Jan 22, 2009
    Have you solved your problem?
  • Toshiba Master
  • 13,433 Answers
I have a RCA digital amplified indoor/outdoor antenna. I need an adapter to connect the coaxial cable from the antenna to the input on the TV.
Robert, Radioshack/The source any type store like this has the adapter you want. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Attach Coax Plug To TV Aerial Cable
Coaxial Cable Connectors Walmart com
TV Antenna Adapter eBay
Aug 27, 2016 | Envizen Digital Quartet 9 Ed8890a Portable...
Trying to connect a DVD player to a TV that is only equipped with a cable jack what do I do
You need an A/V to RF adapter to convert the audio and video outputs of the DVD player to RF so that you can watch the DVD player on an available VHF channel on the TV. See this device offered by Amazon:
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
You may also need a short 75 ohm length of coaxial cable with "F" type connectors on both ends and A/V cables with RCA plugs to complete the setup.
Jan 02, 2015 | Televison & Video
How do I get the correctly connect from the DVD player to the TV set?
It depends on your TV's available inputs. If your TV has an HDMI port, you'll get the audio and HD video to your set with one cable if you invest in an HDMI cable; purchase the cable online (you don't need to pay $$$$ for the cable). Stores that specialize in cables will have the best picture. Press the HDMI select button on your remote to go through the resolution options for the DVD player. (see page 14 of the manual
If your TV doesn't have an HDMI port, check for component video. This will also give an HD picture to the TV. You'll need cables for the 2 RCA audio and 3 RCA (Red, blue, green) video plugs (or one cable with 5 RCA plugs) on each end of the cable. The mega-cables though can be a bit more difficult to plug in. Make sure that the colors match. (Some TVs use an adapter that consolidate the cable connection at the TV. You still need to match the colors at the adapter.)
If your TV only has composite in, you'll have an SD signal at the TV. This is the cable with one RCA plug (yellow) for video and the 2 RCA plugs (red and white) for audio. This cable is often included with the DVD player.
If your TV only has a coax connection (OTA tuner or analog cable), you'll need a Composite to RF converter. These used to be available at Radio Shack and can still be found online as well.
If some countries, the TV might have a SCART port. You can find a composite to SCART adapter.
The manual is available from Toshiba here: http://support.toshiba.com/support/modelHome?freeText=2805086 . Select the Manuals and Specs tab. The file is a PDF; so you will need Adobe Reader or a similar program to read the file.
I hope this helps. If you need additional assistance, please add a comment with details of your TV.
(if your TV has an SD (480i) resolution, you probably only have the composite and coax inputs.)
May 08, 2013 | Toshiba SD7300 DVD Player
Need(lost)a fuse for car power cord for a audiovox D1210 want size is it?
TV/DVD combination unit
1 Left speaker
1 Right speaker
2 Pair of infrared headphones
Wireless remote control
6 "AAA" batteries
ADS-1225PC AC power adapter with attached 6' cord (12 V/2.5 A)
69" Power cord with cigarette lighter adapter (has installed 5A fuse)
7" RCA cable (has left and right RCA audio jacks and an RCA composite video jack on one end and a minijack connector on the other end)
1 Adjustable shoulder strap (has a maximum length of 47")
4 Adjustable mounting straps (each strap has a maximum length of 3')
One 90-degree coaxial adapter (has a 75-ohm coaxial jack on one end and a slip-on 75-ohm coaxial connector on the other end)
1 Storage bag
1 Mounting bag
Operating Instructions
Product Registration card
Dec 30, 2009 | Audiovox Televison & Video
I have a toshiba D-VR610KU combo. Cannot get the
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
Oct 15, 2009 | Toshiba D-VR600
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
Toshiba D-VR610KU
All coaxial inputs or outputs on any unit is the screw-post type. The female part is a standard coaxial cable that slips onto the posts on the unit. Are you trying to convert Coaxial to RCA?
Dec 22, 2008 | Toshiba DVR610 DVD Recorder/VCR
AV input from a game console
try using the RED, YELLOW , and White connections in different holes soemtiems they get crazy and swap video yellow, to video red instead of video being yellow on both ends, figure out which one is the video cable by trying all 3 , to all 3 connections on your tv, while both devices are on
Dec 03, 2008 | Philips Magnavox MPD845
Toshiba DVR610 DVD Recorder/VCR Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
