Question about Acer Computers & Internet
Powersurge, nothing working - Acer Computers & Internet
  • Acer Master
  • 32,281 Answers
First check the power adapter.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 10, 2013
LG 55LH85 LCD tv powersurge
This might need attention of a qualified service technician
Jul 11, 2012 | Televison & Video
ERROR CODE 2000-0142
Hard drive is failing. Reseat hard drive cables. If it does not work, have to replace hard drive. probably damage from overheating or powersurges.
May 15, 2010 | Dell Studio 17 Laptop
Wii will not power back up after sudden power loss any way to reset
This could be bad, also could be good.
1. Check your power outlet and make sure if you have a powersurge protector, that it hadnt tripped. If it is tripped, there is in most cases a button on the side of the powersurge protector for a reset.
2. In the case that this was not on a powersurge protector, try moving the Wii to another outlet and try it from there. If that doesnt work, buy a new power cable. If the new Cable doesnt work, the Wii is most likely Fried and will not be able to be operational again.
DrakeTech
Dec 24, 2009 | Nintendo Wii Console
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When I push the power button nothing happens, no lights, no fan, no anything.
Hello
Thank you for using FixYa. Try these solutions
  • remove ram, and restart. any beeps?
  • Remove HDD and restart, any beeps or messages?
  • Has the unit had a powersurge?
  • Can you check to see if there voltage coming out of the power supply unit?
  • Make sure the DC jack on the laptop is firm - if broken they tend to be loose.
Hope this of some help
Thanks
Richard
Nov 17, 2009 | HP Pavilion ze4547wm Notebook
USB overload
plz chenge your Charge
Aug 18, 2009 | Apple iPod MA446LL/A MP3 Player
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Message usb powersurge
A usb power surge occurs when a usb device is drawing or providing too much power to a port. I would recommend replacement of such device before continueing. To trouble shoot what it is unplug all usb devices, start the computer, then plug devices in one by one.
Mar 03, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Wireless problems
The belkin router needs to be reconfigured to work with the modem first. Call belkin manufacturer for the reconfiguration.
There are some settings in the user page of this router that nedds to be adjusted before you can use the router. If this has been set up before, it is possible that the router has been set back to factory default caused by thunderstorm or it could also be powersurge.
Oct 12, 2007 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
