Question about Envision L32W761 32 in. LCD TV
Can't get a connect from my emachine to aco l32w761
When i connect my desktop (emachine) to my AOC, i get a message that's reads - Video4 Mode Not Supported!
Please Help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 837 Answers
2 options:
1) Try changing your screen resolution to say 640x480 or 800x600 ..
2) Try it in safe mode also ..
Posted on Jan 21, 2009
I've lost the remote control for my AOC Envision L32W761. How can I change the menu and input source options using the front panel controls? I'm able to access the menu screen but can't figure out how to...
Try navigating the screen using the volume and channel controls. If you still can't get to the left side of the screen then try press the menu button again while on the menu screen to see if it'll navigate you there.
Hope this helps :)
Apr 20, 2014 | Envision L32W761 32 in. LCD TV
I have a 32" AOC Envision L32w761 LCD hdtv with no
There are only two things that can cause this problem -inverter and T-con. Since you have already replaced the inverter, it can be nothing other than the T-CON or LCD controller. Replacing the same should resolve the problem. On a side note the inverter/T-Con problem can be isolated easily. The purpose of the inverter is only to light up the backlight of the panel. So when it fails you will still have a faint picture that can be seen if you flash a flashlight on the screen. If you would like me to find you the replacement T-con let me know the part number and I will get you the link to the part.
Sep 07, 2011 | Envision L32W761 32 in. LCD TV
What is the comcast remote code for aoc envision tv L32w761
Directly from Comcast.com
AOC 3,010,017,025,044
Hope this helps.
Aug 27, 2011 | AOC Envision L27W461 27 in. HDTV LCD...
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
W The VGA cable doesn't work/AOC L32W761
I finaly just read te manual on my netbook (go figure) And I was able to toogle over to the external monitor, by hitting <fn> F5 key.
Nov 28, 2008 | AOC A20S431 Television
Envision L32W761 32 in. LCD TV Logo
237 people viewed this question
Top Envision Televison & Video Experts
bigdawg7299
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
