Question about GE / FUF21SVRWW
Door Open light comes on, setting off alarm, even though door is closed & locked. I after resetting alarm, light stays on. Later, light goes off. Does this over & over
Unlocking, opening, then closing & re-locking door has no effect. Alarm still sounds & light remains on.
5 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: freezer door won't close
There are several type of attachments, so pick the one best suited to you....
1. (most likely) With the door open, pull on the plastic panel. If it is held on by clips, it will pull straight off. Look carefully at the clips on the panel. Usually, they bend out of position after being forced back on. Adjust the clips, and gently press back into place. If they are damaged, the clips can be reattached with a 2 part epoxy. I prefer JB weld epoxy.
2. Locate the screws that holds the plastic piece on, and loosen them. Adjust the piece. Tighten the screws.
Best regards, --W/D-- please feel free to rate this solution! thanx!
Posted on Aug 01, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: freezer doorpops open when close
Sorry to read about your problem, I hope this helps you out.
The gasket seals are getting weak.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
Testimonial: "After 6 years, it seems about time for that. How do you redo them??? Thanks you, we figured that out."
heatman101
  • 43501 Answers
SOURCE: WE came home & found the alarm sounding on the
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 20, 2011
MNTECH
  • 1543 Answers
SOURCE: Electricity went out & audible alarm is going
Will stop on it's own when it get cold again, but most generally have a manual alarm shut off (on back, near hinge on older models).
Posted on Apr 28, 2011
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 | Freezers
The door on the freezer will not keep closed. What could be the problem?
There must be something your not seeing, get an extra set of eyes on it.
Oct 25, 2015 | Frigidaire LFFH17F7HW 16.6 Cubic Feet...
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
The open door alarm goes off when the door is closed
THE CONTACT INSIDE THE FRIDGE THAT THE DOOR MAKES CONTACT WITH MAY HAVE DIRT OR SOMETHING ON IT,IF IT DONT MAKE GOOD CONECTION WHEN CLOSED THE LIGHT WILL STAY ON AND THE ALARM STILL CARRY ON GOING OFF.ALSO CHECK THAT THE LEVER INSIDE PUSHIES IN AND OUT AND NOTHINGS BLOCKING IT.ROB
Sep 01, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Frigidaire FFU20F9G (model FFU20F9GW3) temperature light is on
Several things could cause this. To check most things you will need to remove the back wall of the freezer to see the evaporator. It is possible the freezer is low on gas. If it is the coils will usually appear to be only half frosted or less. It is possible the defrost is bad ( I assume this is a frost free) In this case the coils will be totally clogged with ice and no air can circulate. If so you'll most likely have to replace the bi-metal... a circular looking part about the diameter of a quarter clipped onto the coil with 2 wires leading from it. This may also cause the fan to stop running from ice accumulation...or the fan itself could be bad which would also cause a partial meltdown. Unless the machine needs gas an appliance repair person will probably charge you around 100 bucks for most of these repairs..gassing it of course will be more and there is no guarantee how long the gas will stay in it as most leaks are difficult, if not impossible to locate. Hope that helps !
Dec 06, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
GE / FUF21SVRWW Logo
65 people viewed this question
Top GE Freezers Experts
christian nielsen
John Tripp
John Tripp
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
