Question about Lakewood 792/JR Utility Heater
Need a tip over switch for Lakewood model 792/A 1300-1500 watt heater
The front knob on the tip over switch that controls the heat settings is broken and had come off the heater so you cannot turn the heater off or adjust the temperature settings.
SOURCE: Lakewood oil filled heater model 5500
Follow up to my post of 13 January. Out of desperation, I took the heater apart and determined that an electrical fuse-like thermal overload device had opened on the neutral side of the feed to the heating element thus rendering the unit non-working. This device is wrapped in a sheath around the underside of the heating element's electrical connections where the element enters the radiator's core. If the element exceeds the rated temperature it apparently "blows" or electrically opens much like a fuse. The lights still come on but no electricity is getting to the element. When I removed this from the circuit, the the unit began making heat. Apparently, when the heater is on full (both switches on for the full 1,500 watts) the core temperature gets too high. So, I now use my heater on only the 900 watt setting and it's putting out plenty of heat. Today's high is 2F and the room is comfortable. I've no doubt the manufacturer would not condone this modification and I have no intention of turning my modified heater back on "HIGH." Therefore I do not recommend doing this yourself unless you are competent in electrical and soldering work and are sure you won't overheat the unit. Having said that Lakewood clearly has either a design flaw or a bad batch of heater elements or overload protectors out there. When I have time, I'm planning to send my defective protector back to them with a letter. But given that they never responded to my e-mail to their customer service don't expect much in the way of a reply. As they say on TV, don't try this at home.
Posted on Jan 31, 2008
  • 4 Answers
SOURCE: I need the switch for Lakewood 7096 oil heater
This might be the switch,
Defond DRH-2415 15A 125VAC Lighted Dual Heater Switch
Posted on Jan 14, 2009
  • 34 Answers
SOURCE: Lakewood oil radiator heater quit
visit http://www.lakewoodeng.com/html/parts.html for service center info and parts.
Posted on Apr 18, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
  • 3 Answers
SOURCE: my lakewood oil filled heater model 5600/7 just
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Posted on May 10, 2010
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 13, 2011 | Lakewood 5101 Oil Filled Radiator Heater
THE KNOB THAT SETS LOW MED HI AND OFF
heatman101
Feb 13, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood radiator heater model number 5101. The heater just stopped working all of a sudden. The buttons still light up when switched on but there is no heating. please help as I dont have any other...
Sounds as if the element is burnt out or the tstat is broken. the tstat is the more common as they use very cheap ones. Unfortunately you can't get these. My suggestion is to buy a new one.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
Model 707 Lakewood portable heater stopped working
I don't know how to make your heater work again, but I do know (from long experience with Lakewood 707s) that the setting knobs often fail to function properly even if the heating element still works. My solution is to plug the heater into an adapter with an on/off switch on it and use that to control the power. I leave the setting knobs on the heater itself in the position where I usually use them (max heat). These are excellent heaters except for the knob problem.
Apr 06, 2010 | Lakewood LAK707 Utility Heater
Lakewood space heater thermostat source
No I never had any luck and the parts likely 1/2 the cost or more of a new one at wal mart and the heat element would still be old too
Dec 31, 2009 | Lakewood 5101 Oil Filled Radiator Heater
The heater does not work when switched on I have tested the cable up to the internal connection block and checked conntinuity through the thermoststat, all seem ok.Can you help
Someone stated this problem was a resistor located in the neutral side of power cord. That is where the problem is. However, it is actually a thermalink fuse rated at 10 amps. The heater pulls more than 12 amps. I wonder how many of these heaters have ended up in a landfill because of this manufacturing flaw!
Dec 21, 2009 | Lakewood Oil-Filled Electric Radiator...
Switch burned out on Lakewood radiator heater.
Hi, go to amazon.com and you can get a switch for the Lakewood model 905 heater.Best of luck,
Shastalaker7
Nov 24, 2009 | Lakewood 905 Radiator Heater
What is the lower dial for, what do the balls mean ?
The red dials (I think - I can't find a pic where they are facing forward to see them) should control the wattage you have the heater set at. You can set it at 500 900 and 1500 watts usually. The first dial turned on would set the heater at 500. Turning the second dial on will set the heater at 900. And having both on will set it at 1500. And of course the more watts the more heat that will come out of the heater.
Dec 29, 2008 | Lakewood Oil-Filled Electric Radiator...
Dec 08, 2007 | Lakewood (5500) Oil Filled Radiator Heater
Lakewood 792/JR Utility Heater Logo
67 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
Paul Carew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
