Question about Microwave Ovens
Spilled water on microwave
I just spilt about 60ml of water onto my microwave which shorted out my electrics. I unplugged straight away, and have turned the microwave upside down to see if I can drain water out, but will it work again, or should I buy new?
  • Microwave Ovens Master
  • 17,129 Answers
If there was a short, it must be checked out as the fuse would have blown specially with water on the high voltage sections of the magnetron and the PCB. Remove the panels and dry them fully, check the fuse and once you have blown air into and dried, connect to check if the power supply works, If so check if there is any spark due to moisture in the wave guide, check this link: Microwave tips
Posted on Jan 10, 2013
3 Suggested Answers
SOURCE: Whirlpool mh3184xp- microwave and lights turn on by themselves
I am currently experiencing the same problem. I called in Sylvia Brown because I thought that my room could have been haunted...come to find out IT WAS!! She said I did not have a short in my microwave, and that the reason it was turning on was because "the spirit" in my room wanted to kill me. My microwave plate produced a white, foamy, brownish color which she said was what would have killed me. You need to get your houses/apartments looked at if you are currently having the same issue. We thought everything was ok, and come to find out we really were being hunted down by spirits. Run away....FAST!!!!
p.s. this is the above writer's roommate....she's NOT lieing!!!!! be on the lookout for the white foamy brownish spot....it WILL get you, it got me. DUN DUN DUN
Posted on Sep 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a GE microwave.
F3 means that your keypad is shorting.
If you'd like to have us fix it for you, we do that for $39.95 plus parts. We repair them for customers nationwide.
Or if you want to do it yourself, please contact me directly and I'll give you details on parts and procedure.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
Microwave just stopped turning, everything else works
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Jan 05, 2012 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Turntable works intermittently
Good luck.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not rotate on r24stm model
Good luck.
Walesarumi
Sep 29, 2011 | Microwave Ovens
Turn table turns some of the time
Good luck.
Walesarumi
Sep 26, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
A cup of water spilled in my whirlpool microwave and was immediately plugged out, water wiped out and then when I plugged it back in the light came on but also a "cooking sound" I am afraid to...
Hopefully you did not short anything out.
Typically microwaves can handle minor spills.
Unplug the unit..tilt it backwards to drain any excess water..
Let it sit for a day or more to dry out completely..leaving the door open..
If nothing shorted..and I doubt it did..all should be backto normal. Plug it in and test it out.
Best of luck
Apr 19, 2011 | Whirlpool GT1195SH Microwave Oven
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
Good luck....
Mar 21, 2011 | Whirlpool Microwave Ovens
The turntable is not working but I have power
Good luck.....
Mar 19, 2011 | Bosch HMT9656GB Microwave Oven
The turn table doesnt work
Good luck.
Mar 12, 2011 | Daewoo KOC-925T Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not turn
Good luck.
Jan 13, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave Ovens Logo
167 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
