Question about RIM BlackBerry Curve 8520 Smartphone
When i try to safe a image it tells me directory full
    Problem Solver:
  • 6 Answers
You can put a software on your system for Hide software .......
and then saft images
Posted on Jan 10, 2013
My nokia e5 image not deleted in to the gallery pls tell mi solution. error in general system error
It may be that you do not have enough memory left on the card/phone to perform the delete.
OR
You may be just seeing thumbnail images which the phone has stored for faster operation time and the actual image is already deleted..
Try switching it off, removing the battery for a full minute (use the second hand on a watch, cos counting in ones head is often incorrect) and replace the battery again.. Hope this helps!
If not, may have to delete the picture via your PC.
OR
You may have to start the phone up in 'safe mode' (When your phone is switched off , Press the Pencil Button and Power Button Together and wait till your phone start up) and then find & delete the picture, and restart your phone normally to exit 'safe mode'
Nov 04, 2014 | Nokia E5 Cell Phone
I can't take any more pictures because my EasyShare Z981 says my "internal memory is full." How can I fix my camera so I can continue taking pictures?
I'm assuming you have a memory card inserted into your camera? You can use SD or SDHC cards up to 32GB in size. Then, if you look in your camera's manual (direct link if you don't have yours... http://resources.kodak.com/support/pdf/en/manuals/urg01118/Z981_xUG_GLB_en.pdf ) you can see on page 36 how to copy an image from your internal memory onto a memory card. Also, on page 45 you can learn how to use the menu to tell the camera to use the memory card instead of the internal memory. Good luck!
Aug 25, 2011 | Kodak EasyShare Z981 Digital Camera
I have a 4 GB memory card on my Lumix camera. I have downloaded all videos and photos to my iPhoto on my MAC, but the memory card keeps saying full. There is nothing on the camera as far as I can see. ...
Hi, did you click the option to erase the photos from the card after you imported them into iPhoto? It could be that the images are still on the card and that iPhoto has just deleted the directory.
If you are sure that the photos are all on your Mac then the best thing is to use the camera's menu and reformat the card.
I have made a point of NEVER letting iPhoto delete the pictures but I delete them manually in the camera once I know they are safe in iPhoto. However, I am finding that I am no-longer deleting the photos from the card - when it is full I put it aside and use a new one - they are so cheap now - way cheaper than film is.
Jul 17, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
When I attempt to take new picture, window indicates internal memory is full and prevents further use.
Format the memory card.
Formatting, deletes all images from a memory card, even the ones that may have been protected. It recreates the file system including new directories and folders where images are saved on the card
Dec 19, 2010 | Kodak Cameras
Change file size
   Your camera should have came with software to do this,  if it didnt let me know make and model i will find it for you or you can use below method.
    Your original digital photos, whether they be from your digital camera or from a scanner are your "negatives" and should never be touched. Keep them in a safe place and always work on copies of your originals.  My favorite program to change digital photos for emailing is Breezebrowser.
Breezebrowser Method
1) View your photo directory with Breezebrowser (thumbnail images)
2) Select all the images you want to change
3) Under the "Tools" menu select "Proofs"
4) Make sure that "Resize" image is selected and set Max Size to Width of 800 and height of 600
5) Set any image enhancement options you want (i.e. sharpening). You might also want to add a watermark (your name, EXIF photo date, IPTC caption, etc.)
6) In output settings, choose JPEG with Quality 50. The default output directory is a subdirectory called "proofs" but you can change this to whatever you wish.
7) Click on "Proof Selected" then use Breezebrowser to look at the results in your "Proofs" directory (or wherever you have put them).
Mar 16, 2010 | Fuji Finepix Z20fd Digital Camera
The Sharper Image 2GB Mp3 (1612788) Is Not Copying Music Files
The Sharper image 2gb player will only allow 131 entries in the root directory. Create a new folder, just like on your computer, and then add music files to that folder. I have not tested if there is a file limit in a new folder.
Jun 30, 2009 | Sharper Image 1612788 MP3 Player
Clue finders math adventures says cannot creat directory
I found the answer to this problem. The problem is the install tries to write to files in the c:\Documents and Settings\All Users\Documents directory. For some reason, that directory had lost the ownership. Try searching for "my documents access denied". For XP home, I had to boot in safe mode, then take ownership of the directory. Once I did this, the install could write to the directory and it installed!
Apr 21, 2009 | Learning Company, Inc. Clue Finders Math...
I cannot display graphics on my webpage
You didn't indicate the exact nature of the problem. Perhaps the website can't find the graphics. Make sure that you put all the images in their own directory (ie: /images) and make sure you use absolute or full relative referencing in the .html code.
Sep 05, 2008 | HP Computers & Internet
Armada 7400
What operating system do you have and what exactly does the screen say?
Aug 23, 2008 | Compaq Armada 7400 Notebook
Can,t download or burn photos
Most likey the images have been moved from the orginal location. Try locating them by clicking on the Start Menu...Search...Pictures, Music or Video and check off the "Pictures and Photo's" box. Let the search run and see you can find your pictures. Right click on the white space in the seadch results windows and click on View...Thumbnails if you need to view the pics.
If you hover your mouse over the image it should tell you were the image is located (such as C:\Documents and Settings\(Username)\My Documents\My Pictures\(filename).jpg)
You can then go back to Photoshop open the image by going to that directory.
Feb 21, 2008 | HP Pavilion dv1000 Notebook
RIM BlackBerry Curve 8520 Smartphone Logo
14 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
