Toshiba DVR610 DVD Recorder/VCR Logo
Posted on Jan 21, 2009
Need an RCA Adapter for a TOSHIBA D-VR610KU
Need an adapter that will fit on the male end of my coaxial cable and plug into the female port of my DVD/VCR. I went to Radio Shack and they sold me a RF Modulator. I have not even tried it yet. There has to be some type of adapter so that I do not have to use this modulator.
Terry
  • olgagabe Jan 27, 2009
    I have the sme problem. I've been lloking thru the radio shack web site and don't know which 1 it is. A comment a while back said that radio shack had 1 of these adapters.
  • Skicrest May 11, 2010
    Are you trying to go from coaxial to RCA?
Skicrest
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 10, 2009
Skicrest
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
4199
Points
14
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
2answers
I moved the Mintek Tv from my bedroom to the living room, the tv cable cord will not screw into the Tv, I was told that I need a adapter, coax to av-rca, is this correct? What do you think?
Not sure due to lack of information to go on
I. think you need a tv coaxial female to f plug male adapter
really depends on the TV cable cord what is the gender of the end of the cable if it is coaxial male then the adapter needs a female coxial
if the tv has a female socket hole then the f type part of adapter needs to be a male.
The tv manual may shed some more info on the type of RF antenna coaxial connector. it uses.
RCA can be confused as av is to do with with hooking up a Video recorder with Video output being the yellow plug and audio with Red and white plugs.
http://www.4cabling.com.au/rca-audio-and-video-cable-10m.html?gclid=COyD3pvqpsUCFYqCvQodP38A1Q#.VUa9JZM_xhI
I think you need a RF coaxial adapter rather than AV RCA if you are connecting tv to a tv antenna or tv antenna splitter device.
there is a RCA standard that has adapter like below link http://www.radioparts.com.au/product/30255099/pa5099-%27f%27-plug-to-rca-socket-adaptor#.VUa7uJM_xhI
again gender types are needed to be considered before deciding if correct type of adapter..
You could research the rca rf standard to see if it is used in your country. My country uses Pal coaxial standard.
http://www.ebay.com.au/itm/like/271684688400?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=107&chn=ps
tip
How do I Wire a USB Cable to a Stereo Phone Plug
<p>In general, the audio devices use audio cables such as RCA stereo headphones, or telephone cables, connection to other devices. In case you need a USB device to a stereo phone plug, you should use a single adapter cable to connect the USB cable will convert to a stereo phone. <br /> <p><br /> <p>1. Connect the USB end of the headphone adapter to the USB port of your audio device. <br /> <p><br /> <p>2. Connect one end of the headset to your male cable to the headphone port of the headset USB adapter. <br /> <p><br /> <p>3. Connect the other end of your headphone male to male cable to the headphone port of your stereo plug. Now you can connect to any port to connect to stereo. <br />
on Aug 05, 2011 • Cell Phones
Install external monitor from desktop to laptop
If your laptop does not have the 15 pin plug (VGA Port) then you will need to get some type of adapter that will make the monitor work. You probably have a DVI monitor.
You just need to make sure you get the correct type of adapter and make sure the ends that plug into the computer are correct such as male or female. For example think of the human male and female body parts when you look at adapters. The vga port on the computer is called a Female port, but the piece that plugs into it is called Male. It's the same with DVI ports.
I think you need a VGA Male to a DVI Female so below is a link to one and for $2.54 from Cable Wholesale.
http://www.cablewholesale.com/specs/dvi-to-vga-cable/30dv-05300.htm
Below is a picture of what it looks like.
How to install external monitor to laptop if laptop does not support 15 pin plug from monitor
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Can i use my mp3 player with a fisher rs 727 receiver/amp
Yes, just connect a male mini-plug/2 RCA male plug adapter into the mp3 player and connect the male RCA plugs to the AUX IN on the back of the receiver. It may take several pieces to "build" the adapter, e.g. often you'll find a male mini-plug/2 female RCA adapter, so then you'd need an RCA "patch" cable with males at both ends to complete the link.
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
CANNOT FIND CABLE CONNECTION FOR AKAI TV LCT42V6TN
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
5helpful
2answers
Speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Toshiba D-VR610KU
All coaxial inputs or outputs on any unit is the screw-post type. The female part is a standard coaxial cable that slips onto the posts on the unit. Are you trying to convert Coaxial to RCA?
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
