Question about Marantz SR5003 Receiver
Blinking standby light
Was trying to fix static coming from front left speaker turned off reciever when it turned on center channel excursion now receiver will not turn on and has a red (fast) blinking light
robotek
  • 1512 Answers
SOURCE: Marantz Surround SR7500 Receiver (don't know if anyone has this model)
Hi 3303k
Strange dramas you are having there. I would suggest first, that you switch the unit off overnight(unplug at the wall) to allow for a fulll hard reset. Then fire it up in the morning again, and see if it behaves itself. I found a user manual for you online here
It is a good amp that you have, and hopefully resetting it will sort it out for you. If not, please do get back to me here and we shall look deeper..
Thanks for using FixYa, a FixYa rating would be great for looking into this for you. Happy to help further :)
regards
robotek
Posted on May 08, 2008
  • 4 Answers
SOURCE: Marantz SR-18EX; Front left channel crackles
The f-l channel of the sr18, & sr18ex & sr19 is a common failure location due to the heating and cooling over the years. The crackling an/or distortion, is most commonly due to the amplifier going into a high idle, or d.c. offset that can no longer be controlled by the adjustment potentiometers on the board. usually the two 2sc3200 transistors become unstable, and as well a 47mfd and a 470 mfd elect. caps nearby. Also distortion is caused by one or more of the zener and germanium diodes all grouped near the big dual ceramic white resistor. The amp block is held in by six screws. first remove the cross bracket, then cut the cable tie free from the hole on the board. Ten screws hold the top board on, the pull the boards apart from the connectors. before replacing it, resolder ALL of the connector pins to BOTH boards.
Posted on May 27, 2009
  • 8 Answers
SOURCE: Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
Posted on Oct 18, 2009
TOLhamRadio
  • 509 Answers
SOURCE: the receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
Posted on Dec 29, 2009
smarthome2
  • 1114 Answers
SOURCE: SR6004 standby light is blinking very fast
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 14, 2010
Sr576 standby light blinking
Most likely, you have DC Offset(a bad amplifier). The unit is shutting down to protect your speaker system, as well as protect the unit from any further damage. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jul 22, 2012 | Onkyo TX-SR576 7 Channels Receiver
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
NO LEFT, RIGHT, AND CENTER SURROUND
hi there
have u tried connecting the centre speaker to another amplifier to see if the speaker actually works....
if it does then it cud be the output transistors blown or the actual OP-Amp for that channel
Feb 23, 2009 | Harman Kardon AVR 130 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Blinking standby light system will not turn on
I was having a similar problem and determined that there was a short in the speaker leads for the center channel speaker. The leads to the speaker were touching, after being moved, slightly while housecleaning. Once short was eliminated, unit powered on and worked with no problem.
Oct 21, 2007 | Sony DAV-C770 System
Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Aug 30, 2007 | Onkyo TX-DS474 Receiver
Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Sep 06, 2006 | Denon AVR-1603 Receiver
Marantz SR5003 Receiver Logo
76 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
