Question about Crafts & Hobbies
How were roman mosaics made? - Crafts & Hobbies
    Problem Solver:
  • 18 Answers
They had a base made from wood combined with hay, porcelain, and clay. Plaster was then put on top and small pieces of stones or glass were placed to make a picture. There was usually a border made from larger stones/tiles.
Posted on Jan 10, 2013
Roman numerals
Book indexing systems likely require such capabilities. That subject is in the realm of Nancy C. Mulvany (writer of 2005's Indexing Books); but good luck on getting a reply from such lofty heights.
Here is a page referring to how to sort Roman Numerals in Word tables: http://en.community.dell.com/support-forums/software-os/f/3526/t/17598900
Here is some code for sorting Roman numerals: http://stackoverflow.com/questions/6507536/how-to-sort-an-array-of-roman-numerals
Similarly, here is a discussion of use of vlookup: http://www.pcreview.co.uk/forums/sorting-data-using-roman-numerals-t2104212.html and also in the following Excel forum:
http://www.excelforum.com/excel-general/397231-sorting-data-using-roman-numerals.html
I doubt you want to use this online alphabetizer which can handle Roman numerals: http://alphabetizer.flap.tv/
Maybe I have misunderstood the question and you are wondering about something else besides sorting. But here is a link regarding some sql server sorting: http://sql.software.informer.com/download-sql-server-sort-roman-numerals/
Jan 21, 2015 | Games
Tip
How To Remove and Install a MAP Sensor for Your 1988 Dodge Aries
REMOVAL & INSTALLATION
Chrysler Electronic Fuel Injection (EFI), Multi-point Fuel Injection (MFI) and Eagle Throttle Body Fuel Injection (TBI) Systems
  1. Disconnect the negative battery cable.
  2. Unplug the electrical connector from the sensor.
  3. If so equipped, disconnect the vacuum hose from the sensor.
  4. Remove the MAP sensor mounting fasteners.
  5. Remove the sensor from the vehicle.
To install:
  1. Install the MAP sensor into its position and secure in place with the mounting screws. Tighten the screws until snug.
  2. Connect the vacuum hose, if so equipped.
  3. Plug the electrical connector back into the sensor. Make certain that the connector is clean and snug fitting.
  4. Connect the battery cable.
on Nov 22, 2011 | 1988 Dodge Aries
Tip
How to Remove Scratches in Stainless Steel
Whether you can remove a scratch has much to do with how deep the scratch goes. Here are several ways to deal with this problem and restore your cookware, stainless steel appliances, countertops or sinks to their former glory.
Consider using a product made for stainless steel such as Scratch-B-Gone or Bar Keepers Friend.
Or, try spraying an all-purpose cleaner (such as Formula 409) on the scratches.
Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
Rinse the surface and wipe dry.
You may also use a solution such as WD-40 to help fill in the sctraches and coat the stainless steel on the unit(s).
on Oct 19, 2011 | Frigidaire Refrigerators
Hi my Sony tv wont switch on at all. The standby lights goes off like it's going to come on but then the light comes back. I have unplugged. Tried the reset switch at the back but nothing has worked
What is the model number to your Sony TV? It sounds to be a main board fault. Contact any service technician. /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:11.0pt;"Calibri","sans-serif"; mso-fareast-"Times New Roman"; mso-bidi-"Times New Roman";} If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 04, 2014 | Televison & Video
What's Greco-Roman wrestling?
Greco-Roman is an international Olympic sport. In Greco-Roman style, it is forbidden to hold the opponent below the belt, to make trips, and to actively use the legs in the execution of any action.
Aug 02, 2012 | Wrestling
Acer aspire one zg5 no erecovery Pls Help.... Running on Win XP
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 27, 2011 | Acer Aspire One PC Notebook
I have an asus eee pc 4g (linux) and i want to change finnish languge to english. please help....
Changing Languages:
  1. Click on start
  2. Control panel
  3. Regional and language options, there you have the option to change the language to pretty much any language that you want
Sep 26, 2011 | ASUS Eee 4G Notebook
How do i type roman numbers on a computer?
I think you are talking about bullet points, right? You have to start a list and right click on the number. Then go to Bullets and Numbering and select the type of Roman numerals you like (lower or upper case).
Nov 03, 2010 | Computers & Internet
Crafts & Hobbies Logo
861 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
