Question about Numark BATTLE PAK v.4 Turntable
My decks! my numarks started making a very weiry sound, they a direct drive, and i think it maybe the magnet any suggestions on how i can fix it/if its fixable or whats caused it? Thanks.
  • Steve K Dec 15, 2008
    I thing i'm having the same problem. it makes a clicking type noise when rotation power is on and theres any type of resistance on the table (moving records in reverse direction) I've taken it apart 3 times but everything looks fine. I'm stumped here
1 Of My Numarks Has Stopped Working And Only Works When I Push It Round What Could This Be?
Posted on Sep 06, 2008
  • 515 Answers
Do both of your numarks make the same sound? what is the weird sound? The magnet is 1 piece, so I am not sure if it has come loose - very hard to come loose. Check to see if there is any debris inside the magnet/coil area. Sometimes staples, small metal items get stuck to the platter. Just lift the platter off the turntable, to expose the coil and the magnet. If all is clear, then you obviously have a more serious issue. However, you will have to be more detail in describing what kind of problem your having: - Does your turntable power on? - Does it sound weird when you press the play button or does it make a sound even when the platter is not rotating? - This happening to both turntables? - Did you buy these units new or used? - If used, do you know the history of the turntables? - Does it affect the speed or playing ability of the unit? - Do you use the unit on the road? Move it around? - Did this just start happening instantly, or was it something that just got louder over time? I know it's a lot of questions, but I need as much information as possible to properly source the problem via this limited method. - Justin DJPROAUDIO
Posted on Sep 02, 2007
SOURCE:
After playing for 10-15 mins. My song that I am playing starts to slow down and sounds muggy. Then it saids, " calibrating failed, check needle and record'. I have the NUMARK CDX
I'm not certain what type of drive system this deck has but it sounds like it could be a direct drive. In which case it could be that after 15 minutes some kind of semiconductor is getting hot and playing up, so it effects the speed. An examination of the components might reveal a very hot IC or transistor. You could even try to spray it while the device is running and playing up, with Servisol Freezer Spray. If it returns to normal once the suspect part is sprayed, you have a faulty part. You must only spray one suspect part at a time, not allowing the spray to go on other parts, or you will get the wrong result. And if it has no effect, you must allow it to warm up again, before testing another part with the spray.
Jan 12, 2014 | Numark CDX Turntable
Numark IDJ 2USB Flash Drive issues
use the lexar brand jump drive, they tend to work better the the dj station. i have a 64GB jump drive with 3,000 songs on it and it works great with no problems.
Jun 21, 2012 | Numark iDJ2 - DJ iPOD Mixer Docking...
I have numark tt 1610 decks, checked needles on both decks and they are both fine 1 of the decks however keeps skipping even when I try with both needles and different vinyls I've taken the weight off,...
Examine the cantilever very carefully - you sure that the stylus is there? Not uncommon for the lever to be perfecto but the stylus is gone. So when you go to play a record the arm slides all over the place!
Sep 23, 2017 | Numark TT1610 Turntable
My numark ttx deck has started being unable to
Fader has to be ether cleaned or replaced if cleaning did not work.
Nov 17, 2009 | Numark TTX Turntable
MAC Computer wont recognize Numark HDX when connected via USB.
Did you format your hard drives thru the menu on the deck? If not you may need to format the hard drives first and then plug them in. *NOTE DO NOT FORMAT DRIVES THRU YOUR COMPUTER* format the drives thru the decks in the utility menu.
Apr 29, 2009 | Numark HDX Turntable
Numark tt1625
These are direct drive turntables, so if your having speed issues, the problem is probably one of the drive circuits. Unfortunately, not an easy fix. So I suggest taking it to a service center for repair.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 15, 2008 | Numark BATTLE PAK v.4 Turntable
Both decks with same problem.
Nothing to do with the magnet. These are direct drive turntables, and more than likely one of the ICs shorted. Unusual that both shorted out at the same time, so the only thing I could suspect is a faulty power source - make sure all of your cables are free of any exposure to the inner power cable. Also, you might want to invest in a good surge protector (in the $150 range) to protect these babies... I know they aren't cheap. You will need to get them professionally serviced, there are no user replaceable parts inside. If you can't find anyone near you to service these, our company offers free return shipping for all Nationwide service, and if your in NYC, we offer free pick up. Oh, and we are masters with DJ turntables. Unfortunately, I don't think we can post our company information here, as I do not want to violate any agreements. So, with that said, do a search using the REPAIR SERVICE search option in FIXYA.com and go to the following section-> HOME AUDIO -> Audio Shelf Systems - we are listed there.
Aug 04, 2007 | Numark TTX1 Turntable
Numark BATTLE PAK v.4 Turntable Logo
149 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Inno Laur
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
