Question about Schumacher SCUSE826 SE-82-6 6 Amp 12V Trickle Charger for 12V Batteries SE826
Schumacher battery charger
Dog chewd my plug in and all cords i need to know what one are wich so i can put my new leads on
  • 152 Answers
SOURCE: Schumacher 2/10/50 amp charger,125/225 amp starter
It could be an internal fuse, or that the transformer is malfunctioning.
Before any dis-assembly/internal inspection, be sure that the unit in unplugged.
Good luck...
Posted on Feb 25, 2009
  • 323 Answers
SOURCE: need manual
So to this site and download it.
http://manuals.batterychargers.com/manuals/00-00-000496.pdf
Posted on May 28, 2009
SOURCE: schumacher SC7500A DOES NOT WORK
Check the fuse.
Posted on Feb 07, 2010
SOURCE: Issues with Schumacher Battery Charger SE-82-6 -
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
Posted on Mar 14, 2011
  • 6 Answers
SOURCE: Both Battery clips have come off of Schumacher
You need to connect the battery cable wires to the battery in order for the charger to "turn on" the output. If the "reverse polarity" LED lights up, switch the wires. The RED clamp goes to the + battery terminal wire, BLACK goes to the other.
Posted on Sep 22, 2013
How do I open a SC-600A Schumacher battery charger to repair it?
Unfortunately I have the same question. I have removed two screws, but no parts can be pulled off.
The person who wrote the following article apparently knows how to open the charger box.
https://wizbandit.wordpress.com/2008/08/12/hacking-the-schumacher-speed-charge-for-phev-ev-use/
Aug 12, 2015 | Jensen Schumacher SC-600A SpeedCharge High...
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
I have a Schumacher WM-10000A speedcharger and the ground pin on the male plug (built into the unit) has broken off. I need a replacement male plug for this unit. It has been a great charger and I cannot...
Too easy...go to any of the DIY stores, Lowes or the Depot, or your local hardware and pick up a male end for the cord. It's an easy installation, will take you MAYBE 10 minutes.
Jan 27, 2011 | Schumacher & Fast Charge Starter Charger
Issues with Schumacher Battery Charger SE-82-6 - Schumacher 3 Position Slide Switch (8 pins) - Does anyone know how the wires hook-up to to the pins on the back of the switch?
Nov 27, 2010 | Schumacher & Fast Charge Starter Charger
Need to charge 12v car battery
If battery is out of the vehicle, connect positive lead to positive terminal and negative lead to negative terminal.
If battery is in the vehicle, the proper way to connect leads depends on if it's a negative-grounded or a positive-grounded vehicle.
Here is a link to the manual for this charger.
Click where it says "Get This manual" (it's free).
Scroll down to pages 4 and 5 and it give detailed instructions on the proper way to connect leads and a lot more. It's a good manual to keep for future use.
I hope this helps.
http://powertool.manualsonline.com/manuals/mfg/schumacher/se520ma_se5212a_se1275a.html
Sep 22, 2009 | Schumacher & Fast Charge Starter Charger
Schumacher SCUSE826 SE-82-6 6 Amp 12V Trickle Charger for 12V Batteries SE826 Logo
57 people viewed this question
Top Schumacher Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schumacher Measuring Tool and Sensor Expert? Answer questions, earn points and help others
